candle light as sourse
10 replies to this topic
#1 Lens Lenin
Lens Lenin
  • 6 posts
Posted 12 February 2015 - 12:08 PM
i am shooting my collage project , with candle light as source single person candle in his hand, shooting with arri 435 xt, kodat:500T stock , how can i get that flicker effect  and the warm tone of candle  ,elite anamorphic lens maxium opening f 2.8.
Edited by Lens Lenin, 12 February 2015 - 12:12 PM.
#2 Mark Dunn
Mark Dunn
  • 2707 posts
Posted 12 February 2015 - 12:32 PM
Candlelight is quite warm on 3200 stock anyway. a 2.8 is a little slow- Alcott was using 0.7 with 100T using hundreds of candles and some reports say it was pushed a stop as well.
http://www.visual-me...1a/bl/page1.htm
#3 James Compton
James Compton
  • 317 posts
Posted 12 February 2015 - 01:57 PM
 Use candles that have a double wick. It will give you twice the brightness of a normal candle and provide enough brightness for an even exposure on 500T film stock. Place a small 3 or 5 inch fan slightly out of the camera frame, pointed toward the person holding the candle. Move the fan around so that the wind causing the flicker has an inconsistent effect. The flame will appear very warm on 500T film. Now...if you want a very warm effect with out using post production. Use an 85B filter on the lens. That will convert the 500T film into 320 Daylight, make the 2900K flame source very warm on the
5000K balanced filmstock. If you want to see an older movie that has this same effect, check out ' BACKDRAFT'      .   Notice how orange/warm the flames are at 00:43.
#4 Lens Lenin
Lens Lenin
  • 6 posts
Posted 13 February 2015 - 08:49 AM
iam going try it james
#5 Lens Lenin
Lens Lenin
  • 6 posts
Posted 13 February 2015 - 08:53 AM
how can i imitate candle light with tungsten light source ,and flicker effect
Edited by Lens Lenin, 13 February 2015 - 08:57 AM.
#6 James Compton
James Compton
  • 317 posts
Posted 13 February 2015 - 11:57 AM
 There are a few ways to do that. Tell me the size of the area that you are shooting the scene in.  Will the person holding the candle move around inside the frame?
#7 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 13 February 2015 - 04:23 PM
Lots of ways. One way is to have a multiple small tungsten fresnels bunched together and going into individual dimmers. Then you ride the dimmers so that as one goes up another goes down. Try to make it random. There is a device called the Magic Gadgets Flicker Box that will automate the flicker effect for you. Otherwise you need one person on each dimmer.
#8 Dennis Couzin
Dennis Couzin
  • 150 posts
  • Berlin
Posted 13 February 2015 - 05:38 PM
Burn a candle in a dark room.  White things look quite white.  The candle flame itself looks quite yellow.  You see this even when the flame is next to the white thing.
But when you photograph that same candle lit room the white things look quite yellow, while the candle flame itself looks quite white.
It's an example where color photography goes horribly wrong, that is, deviant to how we see.
  • The limited dynamic range of photography dooms the candle flame to burnout.
  • Human chromatic adaptation is more complex than white balancing.
  • Intra picture chromatic adaptation doesn't occur.
I've wondered how pre-photographic artists rendered candle lit rooms.  Here's a good example where the artist (Petrus Van Schendel) painted what he saw.a_market_scene_by_candle_light-large.jpg
What can do but let our camera or film do its thing?  The color relation of the flame to white things comes out backwards and yet acceptable, or we've learned to accept it.   Would persons from candle lit times laugh at our simulations?
#9 Lens Lenin
Lens Lenin
  • 6 posts
Posted 14 February 2015 - 12:27 PM
thanks for reply very help full guys
#10 Lens Lenin
Lens Lenin
  • 6 posts
Posted 14 February 2015 - 12:30 PM
 There are a few ways to do that. Tell me the size of the area that you are shooting the scene in.  Will the person holding the candle move around inside frame
ya he will move the candle ,size normal sized hall
#11 James Compton
James Compton
  • 317 posts
Posted 14 February 2015 - 06:16 PM
That sounds like it will be mostly composed as a wide to medium wide shot. A wide shot will prevent you using additional light fixtures. You should use the double wick candle. If you can hide a small battery powered fan on the actor (perhaps waist level), that will provide the flicker. Just make sure that fan doesn't blow out the candle flame.  :)
