Bolex Super 16 Camera Lenses
16 replies to this topic
#1 Scott Pickering
Scott Pickering
  • 171 posts
Posted 27 February 2015 - 09:33 PM
I just picked up a Super 16 reflex Bolex H16. It was modified to Super 16 many years ago. What I'm wondering if any of the lenses that came with the camera, if they are suitable for Super 16? The seller wasn't sure, since he rarely used the camera and it was 20 years ago. So here is a list of the lenses, and I just need to know if it would support Super 16?
Taylor Hobson Telekinic 2" f2
Kern Vario-  Switar 17-85mm f3.5
Kern Macro- Switar 75mm f1.9
Kern Switar 10mm f1.6
Canon Zoom TV Lens 17-102mm f2.0
I don't know if any of these lenses are suitable, and if not, I can just sell them for a more appropriate lens. Any of these lenses any good?
#2 Chris Millar
Chris Millar
  • 1642 posts
Posted 27 February 2015 - 11:16 PM
Kern Macro- Switar 75mm f1.9 - certianly
Kern Switar 10mm f1.6 - reports are mixed, pretty sure the preset version will cover, but the optics aren't great in the corners, esp, wide open - as for the standard ...
Can't see why the Taylor Hobson wont
Zooms - have you looked through the finder ??
Edited by Chris Millar, 27 February 2015 - 11:17 PM.
#3 Scott Pickering
Scott Pickering
  • 171 posts
Posted 27 February 2015 - 11:25 PM
Never yet looked through the viewfinder on any lens. I just picked up the camera this afternoon. Yet to really play with it. What exactly is a 2" Telekinic lens anyway? It doesn't have a mm for focal length. The Canon zoom I think would work, as it says its a tv lens and I would think a tv camera would have a wider frame sensor inside. Its quite a large lens too. I was told this camera was used by a nature cinematographer. Who- I have no clue. And I really can't tell if this camera is indeed Super 16, as I can't tell from the opening on the lens port. The shutter keeps the film section closed up, so seeing if its Super 16 isn't easy.
Edited by Scott Pickering, 27 February 2015 - 11:28 PM.
#4 Dom Jaeger
Dom Jaeger
  • 1928 posts
  • Melbourne, Australia
Posted 28 February 2015 - 08:37 AM
Lenses in the UK and US were sometimes marked in inches rather than mm, a 2" lens is basically a 50mm.
Like Chris said, the 75mm and 2" should cover S16, the 10mm may exhibit corner darkening. The Vario-Switar won't cover at the wide end, the Canon TV zoom might be OK if it was made for 1" tube cameras. TV lenses were often lower quality optics than cine lenses.
You can examine the camera gate by removing the pressure plate, a S16 gate will have the opening extend closer to the edge on the non-claw side.
#5 Mark Dunn
Mark Dunn
  • 2904 posts
Posted 28 February 2015 - 09:27 AM
You could take a rubbing of the gate if in doubt.
Just to add that TV lenses were intended to degrade fine detail a bit to avoid interference with the line structure of the TV picture (aliasing).
#6 David Cunningham
David Cunningham
  • 1054 posts
Posted 28 February 2015 - 10:50 AM
I can tell you my switar 10mm does cover super16 quite well but is very soft at wide open period, worse at the edges. All the Switars I have a nice and sharp with minimal aberration at f4 and smaller. But wide open in all of those lenses is quite soft, especially at the edges.
I have a 10mm, 25mm and 50mm Switars, each a bit sharper than the other in that order but all quite satisfactory for super16 work. Especially outdoors in natural light where you'd rarely ever by snide f8
#7 Scott Pickering
Scott Pickering
  • 171 posts
Posted 28 February 2015 - 12:32 PM
Ok thanks guys. I only paid $600 Canadian for the package, so I think I got a good deal on it all. Prices on Ebay are way too high and many don't even come with lenses.
I have another question about the camera. The lens turret doesn't seem to rotate to the other positions. Could it be it has been locked in place because of the Super 16 mod?
Oh and to take the pressure plate off- you just unscrew the lower screw holding it in there?
Edited by Scott Pickering, 28 February 2015 - 12:35 PM.
#8 Mark Dunn
Mark Dunn
  • 2904 posts
Posted 28 February 2015 - 12:46 PM
The lens has to be re-centred for S16, so fixing the turret would simplify matters. Otherwise presumably all three ports would have to be altered.
Edited by Mark Dunn, 28 February 2015 - 12:49 PM.
#9 David Cunningham
David Cunningham
  • 1054 posts
Posted 28 February 2015 - 01:58 PM
Most bolex super16 mods I've seen have a set screw in the turret that allows 2 positions. One position is locked in for the sender lens in super16. The other position allows it to rotate per usual back in the original regular 16 position in case you want to shoot 4x3 for whatever reason.
#10 David Cunningham
David Cunningham
  • 1054 posts
Posted 28 February 2015 - 02:08 PM
Center. Not sender.
I think this one is set up the way I was saying:
http://4.bp.blogspot...ontal+3%3A4.jpg
You just loosen that center screw and it allows you to slide it back and forth to regular vs super16 centering.
#11 Scott Pickering
Scott Pickering
  • 171 posts
Posted 28 February 2015 - 03:18 PM
I got a message from the seller and he stated I have to unscrew one of the caps to have it unlock. Which means I think all three holes are useable. Which again makes me wonder if this camera is truly Super 16. Im going to have a closer look at it and hopefully get an answer.
#12 Scott Pickering
Scott Pickering
  • 171 posts
Posted 28 February 2015 - 04:48 PM
So I inspected the gate on the camera and it looks like I have a regular 16mm camera. Either the seller mislead me, or he didn't know himself what he had. Im going to have to talk to him about it. What I see is the metal guide on the left doesn't seem to be machined for the wider gate, and the gate itself looks too square for Super 16. I'm posting two pictures for you guys to confirm. All I know is its going to cost a bundle now just to convert his camera. I might just sell it and get a better Bolex in the end, and keep some of the lenses. But before I do anything, can you guys confirm my suspicion this is indeed a regular 16 camera?
#13 Scott Pickering
Scott Pickering
  • 171 posts
Posted 28 February 2015 - 04:51 PM
Ok this site is not allowing me to post images or direct links to pictures. So it looks like I'm going to have to pass on showing the pictures. The website they are on doesn't show pics to non-members either, so Im stuck on that.
#14 Chris Millar
Chris Millar
  • 1642 posts
Posted 28 February 2015 - 06:40 PM
Well if the gate shows no widening, it isn't super 16.
On a plus, your lenses will cover :)
But yeah I'd be researching the cost of a conversion, then asking for that refund, or a simple return as the conversion cost is likely more than the purchase.
It's a pity, makes you wonder about the seller - but best just assume they were genuinely mistaken.
#15 Scott Pickering
Scott Pickering
  • 171 posts
Posted 28 February 2015 - 07:29 PM
He was mistaken. I got a text from him saying it was his mistake and that he will refund the money I paid him. There is a SBM I was looking at I'd like to get. So I may go for that assuming its still for sale by then.
#16 Chris Millar
Chris Millar
  • 1642 posts
Posted 01 March 2015 - 04:36 AM
SBM is a much more straight forward conversion...
By the eay, if either of the 10mm or 75mm switars have little levers on them they are the 'preset' models. If so, maybe you want to keep that deal :)
Check out eBay prices on them!
#17 Arthur Sanchez
Arthur Sanchez
  • 144 posts
  • Tijeras, NM
Posted 27 October 2016 - 08:57 PM
Hey Group...
What cameras are you referring to... or needing converted? Bolex? or other?
