Can anyone look at these DPX files and make them look good?
10 replies to this topic
#1 Phil Thompson
Phil Thompson
  • 318 posts
Posted 21 March 2015 - 05:09 PM
Hello there,
Anyone? I've attached a link to some raw DPX frames. Can anyone mess about with these and make them good?
DPX FILES
https://www.filemail.com/d/pmtbrmahsldqgit
#2 Phil Thompson
Phil Thompson
  • 318 posts
Posted 21 March 2015 - 05:18 PM
It's from a 35mm feature me and a friend have just finished. Ideally we need a london based colourist to help us out finish it. Essex Stargate is the name (pending MGM clearance - so probably won't be that....)
#3 aapo lettinen
aapo lettinen
  • 1083 posts
  • Finland
Posted 21 March 2015 - 05:44 PM
there's about million ways to treat these shots, just messing with gamma curves and changing the mid/shadow color balance makes them better. for the ext shot you may want to change the sky color
#4 Phil Thompson
Phil Thompson
  • 318 posts
Posted 21 March 2015 - 06:02 PM
Do you mind having a look at these too?
https://www.filemail...enhgovqfoynktdz
#5 Phil Rhodes
  • 12069 posts
Posted 21 March 2015 - 07:09 PM
Where'd you get them from? Photoshop won't load them.
#6 aapo lettinen
aapo lettinen
  • 1083 posts
  • Finland
Posted 21 March 2015 - 07:25 PM
the first ones are 8-bit and have some alpha problem, I could open them in AE when set the alpha matting to "ignore"
#7 aapo lettinen
aapo lettinen
  • 1083 posts
  • Finland
Posted 21 March 2015 - 07:29 PM
I sent Phil T. some quickly corrected samples, I think most of the shots can be easily corrected just with contrast tweaking and changing the colors slightly. some slight magenta cast has to be removed and shadows neutralized. some shots may need secondary correction to skin colors and maybe skies but that is also quick to do
#8 Scott Pickering
Scott Pickering
  • 159 posts
Posted 21 March 2015 - 10:18 PM
I was only able to open 2 of the many files listed here in Premiere Pro. I did a basic "Auto Color adjust" and Auto contrast and it looked pretty good at that point. The file where they are all sitting on a couch in a room, what bit depth was that DPX file? I'm looking at getting either 10 bit or 16 bit DPX files made from my films, and wonder what the program will open.
#9 Phil Thompson
Phil Thompson
  • 318 posts
Posted 22 March 2015 - 05:06 AM
nuke opens them
#10 aapo lettinen
aapo lettinen
  • 1083 posts
  • Finland
Posted 22 March 2015 - 06:10 AM
after effects cc also opens them. if you see black frames you should change the alpha matting settings at import or by using interpret footage.
Resolve or Photoshop could not open at least the first 4 shots, did not try with Premiere
#11 samual d'souza
samual d'souza
  • 1 posts
  • Colorist
Posted 29 April 2015 - 09:49 AM
Hello Phil,
still looking for people to make those DPXs look good?
