PL lens to Canon EF adaptor?
#1 Dominic Disla
Dominic Disla
  • 13 posts
Posted 30 March 2015 - 12:16 PM
Is there such a thing? If so, how does the quality compare to a Canon 7D that has been permanently changed to allow PL lenses?
#2 aapo lettinen
aapo lettinen
  • 1172 posts
  • Finland
Posted 30 March 2015 - 02:03 PM
the main difference is that the pl to ef adapters don't allow to use lenses which have long mount so you can't use all cine lenses with them. I think about 5/6 of existing PL lenses don't fit.
the problem is mainly the depth of the 54mm cylindrical part of the lens's pl mount.
With PL modified 7D you can use most of the existing PL lenses without problems because the clearance is much better. the mount may also be better quality depending on which conversion you choose
#3 Dominic Disla
Dominic Disla
  • 13 posts
Posted 30 March 2015 - 02:51 PM
Would a 28mm fit?
#4 aapo lettinen
aapo lettinen
  • 1172 posts
  • Finland
Posted 30 March 2015 - 03:20 PM
I think the max is more like 7mm or so
#5 aapo lettinen
aapo lettinen
  • 1172 posts
  • Finland
Posted 30 March 2015 - 03:23 PM
canon ef  ffd is 44.0mm
arri pl ffd is 52mm (-0.01)
52- 44 = 8mm
8mm - 1mm for the adapter = 7mm
sounds about right  :(
Canon ef diameter is smaller than 54mm so there's nothing you can do basically other than changing the whole ef mount
Edited by aapo lettinen, 30 March 2015 - 03:25 PM.
#6 aapo lettinen
aapo lettinen
  • 1172 posts
  • Finland
Posted 30 March 2015 - 03:35 PM
I think nowadays it might be better to choose a M4/3 or E-mount camera with PL adaptor than adapting Canon cameras to PL hard mount.
you can also choose a Blackmagic camera with either PL adaptor or with PL hard mount.
I personally use GH4 when needing adaptable system (I use for example PL, B4, Nikkor, EF, C-mount, Pentacon Six, Pentax 67, oct-18 lenses with it. very versatile but noise/sensitivity is a bit of a problem sometimes)
