KINOPTIK TEGEA, WHICH MOUNT IS THIS?
7 replies to this topic
#1 Giorgio Taricco
Giorgio Taricco
  • 159 posts
  • Toino Italy
Posted 03 April 2015 - 07:53 AM
Hi gents,
does anyone know what mount is on the Kinoptik Tegea 9.8mm in the pics?
Never seen one and I can't recognize it.
Thanks for your help.
Giorgio
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 777 posts
  • Montreal, Canada
Posted 03 April 2015 - 07:59 AM
This is what is called a ruggedized mount for an instrumentation camera. Used when the camera will attain high velocities and be subjected to strong vibrations.
#3 Mark Dunn
Mark Dunn
  • 2896 posts
Posted 03 April 2015 - 08:12 AM
Might there also be a C-mount under there somewhere?
Edited by Mark Dunn, 03 April 2015 - 08:13 AM.
#4 Giorgio Taricco
Giorgio Taricco
  • 159 posts
  • Toino Italy
Posted 03 April 2015 - 08:18 AM
Thanks Jean-Louis,
the mount can be disassembled by four screws but what would be the original mount under it?
The seller says that Arri Standard to C mount adapter fits fine but the lens can not reach infinity focus,
I have some other pics that could help, it's an Arri Standard mount?
Giorgio
#5 Giorgio Taricco
Giorgio Taricco
  • 159 posts
  • Toino Italy
Posted 03 April 2015 - 09:09 AM
Found on the Kinoptik website that the Kinoptik lenses were aailable also with STALEX MOUNT, (high speed cameras), so I think it's a Stalex mount.
Now I would try to see if the lens is standard and if I can fit a c-mount on or adapter, any help about the Stalex mount?
Giorgio
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 777 posts
  • Montreal, Canada
Posted 03 April 2015 - 12:06 PM
Probably, you'll have to get a custom mount manufactured.
What camera are you planning on using this on?
Jean-Louis
#7 Giorgio Taricco
Giorgio Taricco
  • 159 posts
  • Toino Italy
Posted 03 April 2015 - 01:37 PM
I will use it on my Beaulieu 2016 Quartz and on the Blackmagic Pocket but I don't know where to find a tech to do the work...
What do you think about? I don't want to spend more than buying a Cameflex or PL standard Kinoptik lens.
Maybe Lee Bosher in UK will be able to do the job?
Giorgio
#8 Jean-Louis Seguin
Jean-Louis Seguin
  • 777 posts
  • Montreal, Canada
Posted 03 April 2015 - 01:50 PM
Since the lens is designed for 35mm cinema frame, it would make sense to convert it to PL first and get a PL to C-mount adapter for your cameras.
In recent years, this lens is often completely re-housed in a new barrel with geared focus and f/stop rings. In PL mount.
Jean-Louis
