Quality Without Lighting on 16mm
#1 FilmmakerJack
FilmmakerJack
Posted 14 May 2005 - 03:30 AM
Hey, I'm shooting a day shot. There's adequate lighting from the sun and if it were completely outdoors, I think I would be fine. However, my character is in a car. I was wondering what were some thoughts as to what I should do to fix the lighting, or if it should be good enough to shoot for a more natural feel.
#2 Gareth Munden
Gareth Munden
  • 137 posts
  • London UK
Posted 14 May 2005 - 05:55 AM
Hi , why not shoot some 35mm still photos as a test ? Ask in a camera store for a film with similair props as the 16mm film you are using .
Take white card etc , to bounch light back into faces etc .
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 14 May 2005 - 08:16 AM
<{POST_SNAPBACK}>
You should base your exposure on the main subject (the character in the car). But unless you try to balance the lighting and control contrast, it's likely things outside the car will be quite washed out. If you are using negative film, its superior highlight latitude may keep a bit more detail in the highlights, whereas the really bright areas may "clip" on video. In either case, a big part of cinematography is controlling the light.
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 14 May 2005 - 08:33 AM
My personal opinion is that overblown exteriors in car windows aren't very pleasing. If the car is stationary all you need is a reflector. This can be a white board or cupboard-door draped in tin foil - whatever. Another good trick is negative fill to increase contrast - I have many times draped a big black tarp over the windows not in shot to create a more contrasty look.
#5 David Mullen ASC
Posted 14 May 2005 - 09:13 AM
If you absolutely can't light the car, or bouce anything, try driving so that the background is backlit; this allows you to open up more for the shadows, exposure-wise. Even better, drive backlit with a dark green background like trees.
