Arriflex 16 SR 1 Camera has power but won't run!
Arriflex. Arri 16 SR 16 SR I 16 SR 1
#1 Luis Tittanegro
Luis Tittanegro
  • 2 posts
  • Berlin
Posted 09 April 2015 - 01:56 PM
I have an Arriflex 16 SR 1 that has stopped working.
When I flip the switch to run, the motor does not start and a red light comes on inside the view finder. The battery is fully charged tested it with a multi meter, and tried a different battery to be sure.
The owner’s manual says that a red light will come on in the view finder when the camera doesn’t have enough power to maintain a sync speed.
Has anyone else experienced this problem?
Does anyone know what the cause of this problem would be? Could it be that the voltage regulator is broken, or maybe the sync crystal is malfunctioning?
Does anyone know where a more detailed camera manual for this camera can be found? Like a troubleshooting or service and repair manual.
Tks
#2 James Jeffrey Cotter
  • 32 posts
  • United States
Posted 09 April 2015 - 02:47 PM
The SR manual
http://www4.uwm.edu/...ras/Arri-SR.pdf. I would see how much amperage your batteries putting out it could be 12 volts but very weak. Then check voltage at where it enters motor with your voltmeter see if it is making it there, if yes try powering the motor using jumpers to see if it will work independent of the system. If gets power with adequate amperage and voltage then see if it is mechanically free to spin.
#3 Luis Tittanegro
Luis Tittanegro
  • 2 posts
  • Berlin
Posted 09 April 2015 - 05:32 PM
Hi James,
I bought a new 12 Volt battery 4.5 Ah/4500 mAh with smart charger 9.6 Volt-18V NiMh from Du-All Cameras! I think it's the right battery pack for the SR 1 or not?
Thanks for the informations
