Safety wire/glass for Ianebeam/Strand 2kw Blonde?
lighting kit strand ianebeam 2kw blonde
14 replies to this topic
#1 Bradley Stearn
Bradley Stearn
  • 121 posts
  • 2nd Assistant Camera
Posted 10 April 2015 - 07:01 PM
I own an old Ianebeam 2kw. It works great, and so far this year it has been used on an almost weekly basis on the shoots that I work on. I was wondering if anyone knows of somewhere to purchase safety mesh/glass to put into the light, as the moment it is just fully open, and that worries me a little! I would never use this light in  a tight space, I have mainly used it to light interiors from the exterior, so it's always placed away from actors/crew. It would be nice to complete the light with some safety mesh, or even a scrim for safety.
#2 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 10 April 2015 - 07:46 PM
The is a Strand/Ianiario/QuartzColor "blonde"?  Here's a parts sheet, you want the wireguard for the accessory holder.
http://www.prisma-scene.com/parts/strand/2004/pdf-str-2004/blonde2000.pdf A shot in the dark:
http://www.etnow.com...for-quartzcolor
#3 Tim de la Torre
Tim de la Torre
  • 5 posts
Posted 06 October 2016 - 02:06 AM
I have the same question. Where can you find parts for an old light like this in the US?
#4 aapo lettinen
aapo lettinen
  • 1219 posts
  • Finland
Posted 06 October 2016 - 03:57 AM
those nets last like forever so you can very well buy the original one if you find any. but if not, I think any Chinese Blonde counterfeit accessory would do for this as long as the mesh is right type for the job.
I'm pretty sure that those Dynacore etc. cheaper lights have similar enough net that it can be used with the Ianebeam without any problems  ^_^
#5 JD Hartman
JD Hartman
  • 1809 posts
Posted 06 October 2016 - 08:37 AM
Except none of the Fareast counterfeiters I've contacted will sell parts.
#6 Brian Drysdale
  • 5343 posts
Posted 06 October 2016 - 12:34 PM
You can still buy these lights in the UK, however, you may need to do same digging around for their US agent. Alternately, you could check importing the part from the EU, the currently the pound is weak against the dollar.
#7 JD Hartman
JD Hartman
  • 1809 posts
Posted 06 October 2016 - 02:59 PM
Well....I called the company HQ in Italy and after speaking to several people was assured that a US rep would contact me.    That never happened...
#8 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 06 October 2016 - 06:31 PM
Google found this list of businesses selling new and used strand parts in the UK and elsewhere.  May be mostly but not all theatrical gear.
http://www.theatrecr...elp/spares.html
Just had a look and it wasn't easy to find what's usefull in there.
The cheap redheads seen in NZ,  and the cheap blondes seen on eBay may not be exact copies.  For example I notice that the barn doors look integral with the mounting ring that fits to the lamp body.
Hijacking Bradleys thread....
(old,  bent out of shape,  cheap is fine)
Anyone got a couple of Blonde Ianebeam 2K barn doors,  one Ianebeam 2K accessory holder ?  The old Ianiro ones seem to fit.
Also a Strand redhead barndoors.  The Ianebeam barndoors fit ok.
Two wire mesh for 2K blondes...Bradley has first dibs of course.
Edited by Gregg MacPherson, 06 October 2016 - 06:46 PM.
#9 Brian Drysdale
  • 5343 posts
Posted 07 October 2016 - 02:42 AM
Aren't the Stand Redheads just relabeled Ianebeams.
#10 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 07 October 2016 - 07:41 AM
The Strand branded ones I see here look like this.  There is no "accessory holder".  The wire mesh just sits under the mounting ring.
http://www.trademe.c...-1168243343.htm
#11 Brian Drysdale
  • 5343 posts
Posted 07 October 2016 - 07:57 AM
This is the one I was thinking of: http://www.theatrecr.../q_redhead.html
#12 Tim de la Torre
Tim de la Torre
  • 5 posts
Posted 07 October 2016 - 12:58 PM
Can you just use some home depot mesh and a metal wire around the lamp to secure it? lol... probably would look tacky but would work, right?
#13 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 08 October 2016 - 11:47 AM
The retaining thumbscrews would catch on the mesh I think.  It might work without the wire.
The original mesh is made a ring with a C section that is  squashed flat onto the mesh.   Tricky to make.  You could braze/weld/solder mesh to a thin ring I supose.
#14 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 10 October 2016 - 08:02 PM
I just had a look at an original mesh from a Strand 800w redhead.  Not a pressed C section with the mesh captured.  Just two thin rings,  the mesh between,  looks welded.
#15 Brian Drysdale
  • 5343 posts
Posted 15 May 2018 - 06:47 AM
I've just had to replace one and the Cosmolight 2K safety glass fits the Ianiario/QuartzColor Blonde. Multi-lite are the UK agent.
Also tagged with one or more of these keywords: lighting, kit, strand, ianebeam, 2kw, blonde
