Just Got Bolex H16 Rex5- What Am I Missing?
14 replies to this topic
#1 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:16 PM
Other then the lens for the camera itself, what am I missing to be able to use this camera with the motor drive it comes with? Do I really need a sync sound cable plugged in to use the motor on this thing? And where is the battery? I do know its missing the rollers for the inside of the camera to be able to use the 400 foot magazine. These rollers guide the film inside the camera when using the big magazine. What else do I need to buy so I can be off and running?
#2 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:18 PM
More.
#3 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:20 PM
More again.
#4 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:21 PM
Still more.
Edited by Scott Pickering, 11 April 2015 - 05:22 PM.
#5 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:23 PM
Lastly.
#6 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:25 PM
And while we're on the topic of what parts are needed, what would be a good zoom lens for this camera that isn't too expensive and will cover Ultra 16?
#7 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 05:37 PM
One other question- if the battery is located in the motor itself, I'm assuming the charger supplied here will be usable? I tried plugging the charger into the motor and the needle on the meter didn't budge one bit. Also pressing the button on the motor release didn't activate the motor either. So could the battery in this thing be dead (assuming this thing has a battery)?
#8 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2015 - 08:13 PM
Are tv zoom C mount lenses sharp enough for 16mm? I see lots of them on Ebay, but not sure if a TV zoom will reduce resolution when using film?
#9 Mark Dunn
Mark Dunn
  • 2896 posts
Posted 12 April 2015 - 04:30 AM
The battery isn't in the motor. it's in the charger unit. Judging by the condition the battery may have had it and will need recelling.
The mag motor gets its power via the 2-pole socket in the motor.
Have a look here.
http://www.bolexcoll...es/motor60.html
Edited by Mark Dunn, 12 April 2015 - 04:32 AM.
#10 Chris Millar
Chris Millar
  • 1642 posts
Posted 12 April 2015 - 06:24 PM
Hi Scott,
Welcome to Team Bolex!
Hrrrm, looking at the surface corrosion of some of the external parts it looks like what might be missing is a good internal service, it's not trivial and may cost a bit relative to the cost of the machine, but there are still lots of techs about, a few here in the forum.
A TV zoom lens won't have the 'RX' correction to account for the prism on your boles, you'll get an image of course, but it won't be as sharp esp. wide.
My RX4 (non-magazine) has a set of primes only, not saying it's exclusive, it just feels a mechanically unsound having all that mass levered off not only a c-mount but the turret also - there are solutions, such as the locking plug thingy and a kind of rod based support, but the bayonet mount models are where I opt for zoom.
Edited by Chris Millar, 12 April 2015 - 06:25 PM.
#11 Scott Pickering
Scott Pickering
  • 171 posts
Posted 14 April 2015 - 08:02 PM
Chris- What will happen when I try to use the non RX lens on my camera? Will it be a viewfinder focus problem, or will the film itself be out of focus? I don't mind manually focussing a shot, but if it will be out of focus on the film- then I'll have to resell the lens.
#12 Simon Wyss
Simon Wyss
  • 1635 posts
  • Near Basel, Switzerland
Posted 15 April 2015 - 12:38 AM
The prismatic focus displacement is a problem with focal lengths shorter than 50 mm and at apertures bigger than f/3.3. The exposure would be affected and you are misled by the viewfinder but to a different degree. Such a beast is the double-prism reflex system of Paillard-Bolex.
TV camera lenses are slightly different in their colour correction, i. e. to a narrower depth of residual longitudinal chromatic aberration. With film lenses that aberration is sometimes left matching the spacial arrangement of the different colour sensitive layers. You have about two to three hundreds of a millimeter or a thousandth of an inch of imaging layers total thickness. But beware, it depends on the individual lens design. The story becomes still more complicated with your reflex prism. I’d stay away from TV camera zooms and use RX marked lenses by Kern, Angénieux. Schneider, Berthiot. Not sure whether Rodenstock had made lenses for Bolex RX.
See also this.
#13 James Jeffrey Cotter
  • 32 posts
  • United States
Posted 16 May 2015 - 03:50 PM
Angenieux 12-120, preferably bolex specific, is a great lens for this and of course the Kern Switar Zooms. You need the roller as you already mentioned. That power supply is an easy re-cell you do not have to match the battery size just the voltage amperage.But really get that camera to a tech to clean and lube and adjust. You would be amazed at the little fragments of film and emulsion, dirt,grit etc that make it into the magazine. The worst I find is after 20 years grease has had much of it that has evaporated and what is left is a sticky light brown to red tar substance very dry and a major impediment to movement of the mechanism. I only work on Arris but I am shocked some of the stuff people sell on ebay and its bone dry and like a film garbage can inside.
#14 Scott Pickering
Scott Pickering
  • 171 posts
Posted 31 May 2015 - 10:26 AM
What would be a good lens for the Bolex if I'm wanting to convert the camera over to Ultra 16? Also I don't want to spend a huge amount of cash on the lens, as this camera won't be used a whole lot while in my possession.
#15 Doug Palmer
Doug Palmer
  • 382 posts
Posted 31 May 2015 - 03:23 PM
I would think any of the Bolex RX lenses will be fine for Ultra-16.  This format's quite a lot easier to cover than super-16, yet almost as wide.  I use the 10mm Switar alot with ultra-16.
