Milliken DBM-4c Help
Milliken 16mm Highspeed Help
#1 Cody Ryan
Cody Ryan
  • 4 posts
Posted 12 April 2015 - 04:46 PM
Hi Guys,
Just picked up this Milliken for $30 figured I give it a shot. Had some questions about the wiring. It has this cable coming out of the front and a Hi Lo Off switch on the back. Haven't seen any of them with this and was wondering if this camera has had any rewiring. Also what they are for. I assume that the cable might be for power if it has been rewired. Thought I check with you guys first before I did anything with it.
Thanks Cody
#2 Mark Dunn
Mark Dunn
  • 2897 posts
Posted 13 April 2015 - 04:52 AM
I wonder if the 4-pin was for some kind of lens control. The Hi-Lo switch might be a speed range selector.
IIRC the medium-speed cameras usually have just the one cable for power, control and timing lights. It's the high-speeds that need a separate power inlet for the higher current.
BTW we called up to 500pps medium-speed, not high, so that would cover the Milliken.
Edited by Mark Dunn, 13 April 2015 - 04:56 AM.
