Cheaper alternatives to Dedolights?
dedolights
30 replies to this topic
#1 David Peterson
David Peterson
  • 246 posts
  • Auckland, New Zealand.
Posted 24 April 2015 - 06:15 AM
Anything similar to Dedolights 150W/100W but cheaper? I really like them when I've used them, but they would seriously stretch my budget to buy a set.
Edited by David Peterson, 24 April 2015 - 06:16 AM.
#2 Bradley Stearn
Bradley Stearn
  • 121 posts
  • 2nd Assistant Camera
Posted 24 April 2015 - 04:24 PM
Try looking at a set of Lite Panels sola LED ENG. Im not entirely sure, but my guess is that being LED, they are cheaper than Dedo lights.
From experience, they offer a similar quality of spotted light, with the flexibility of having a wider flood if needed.
#3 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 24 April 2015 - 06:25 PM
Try the ETC scorch four mini ellipsoidal.  Its no exactly the same but focusable, has the same benefits as the Source 4.
http://www.etcconnec...i/Features.aspx
#4 Phil Rhodes
  • 12283 posts
Posted 24 April 2015 - 06:38 PM
In extremis, birdie parcans and blackwrap. Battery powered!
#5 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 25 April 2015 - 01:05 AM
Not really. What makes Dedos special are the dual lens optics, which are not cheap. If you can deal with a normal fresnel, then a 150w or 300w would probably be the closest to a classic Dedolight. Arri or Mole will last you the longest. Just don't get an LTM Pepper, those things fall apart pretty quickly.
#6 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 25 April 2015 - 03:06 AM
+1 to Satsuki's point.
What's special about Dedos is that they're Dedos, the optical elements in the fixtures are what gives you such precise control of the beam.
I have a couple of both 150w and 650w Dedos for precisely that precision. They are pricey, but totally worth the outlay - they're built to last so they'll give you 20 years of usage no question if you don't abuse them.
They can also be rented quite cheaply and easily, so if you can't fork out the cash to buy just yet, renting is always an easy option.
Here's my four in a Dedolight Soup:
And the results:
F51748.jpg?format=1000w
5cBdP1c.jpg?format=1000w
Buy once, cry once is my philosophy David, the nice thing about Dedos is that there's rarely any crying involved, just smiles. Mine come out on almost every scene I light, and have easily paid themselves off within a year.
#7 JD Hartman
JD Hartman
  • 1786 posts
  • Edison, N.J. U.S.A.
Posted 25 April 2015 - 06:48 AM
+1 to both Satsuki and Mark.
Dedolights are quick and precise.
I may be wrong, was their forerunner the 200w Mini-Mole or Midget with a Focal-Spot attachment?
#8 andrew ward
andrew ward
  • 269 posts
Posted 02 May 2015 - 01:57 AM
Kenfield, that Umbrella rig is mega weird.
#9 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 02 May 2015 - 05:49 PM
I knew you'd like it Andrew ;) probably almost as much as you'd enjoy my 'Orb Light' self-contained, wheel-aboutable book light...
#10 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 02 May 2015 - 06:24 PM
Lol, I was thinking the same thing! Results look great though. What's inside the homemade Jemball?
#11 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 02 May 2015 - 07:06 PM
Whatever you want (that's one of the beauties of it!). Sometimes I use one or two 2k open-faced blondes (clean or corrected for daylight), sometimes I use a 1.2k or 1.8k HMI.
One of my favourite aspects of the 'Orb' is how lumen-efficient it is, you get a fraction of the spill you get from a conventional book light, so you can get away with lower-wattage fixtures and still have silky soft light.
In that photo above it's a 1.2k HMI, and here's the end result:image.jpg image.jpg
#12 andrew ward
andrew ward
  • 269 posts
Posted 02 May 2015 - 08:32 PM
You have umbrellas that can take 4k of tungsten?
And how do you mount the head so it doesnt shadow itself?
#13 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 02 May 2015 - 10:10 PM
Looks nice!
#14 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 03 May 2015 - 07:13 AM
Well the brollies are 7' in diameter, so there's enough space between things for heat to not be an issue, even with 4k of tungsten. I use Triple-Headers to mount everything to the one stand, and that spaces things out nicely.
I pull the barndoors off the fixtures, and compared to the size of the umbrellas, they're just not very big, so shadowing isn't really an issue by the time your bounced light is filtered back through the frontal diffusion.
You also get the added benefit of nice, circular catch lights in talents' eyes, which I tend to prefer.
Add all of those benefits to a key light that you can setup (singlehandedly) in about 4 minutes, and wheel about set to reposition in mere seconds, and you have a pretty nifty little setup. :)
#15 andrew ward
andrew ward
  • 269 posts
Posted 03 May 2015 - 08:33 AM
Really?
I have some westcott umbrellas somewhere but i thought they were just for strobes so i figured theyd melt with anything continuous through them.
#16 JD Hartman
JD Hartman
  • 1786 posts
Posted 03 May 2015 - 08:58 AM
Am I missing something....what's inside your rolling "orb light"?
#17 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 03 May 2015 - 09:10 AM
Really?
Give them a shot, they work a treat for me (though again, the broader spacing of the big 7' brollies certainly improves the heat situation, a smaller brollie, with the components closer to the heat, may not fair as well).
Mentioned it above - Whatever I want (that's one of the beauties of it). Sometimes I use one or two 2k open-faced blondes (clean or corrected for daylight), sometimes I use a 1.2k or 1.8k HMI.
#18 JD Hartman
JD Hartman
  • 1786 posts
Posted 03 May 2015 - 10:48 AM
How about some construction detail of the Orb?  Image of the insides, grip hardware used, etc?  Please....
#19 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 03 May 2015 - 09:15 PM
I can't find any detailed images of the construction (I'll take some next time I set it up), but it's super simple:
Ingredients:
- 1x Combo Stand
- 1x Wheel Set for Combo Stand
- 1x Triple Header
- 1x 7' 'Shoot Through' Umbrella
- 1x 7' 'White Bounce' Umbrella
- 1x 2.5" Grip Head
- Lighting Fixtures to taste
Recipe:
- Put your wheels onto your combo stand
- Put your Triple Header on top of your combo stand
- Put your Grip Head on the centre mount of the Triple Header
- Put your light fixture(s) on the outer mounts of the Triple Header
- Feed your two Umbrellas through opposite ends of the larger hole of the Grip Head and tighten
- Wheel the 'Orb Light' into position, turn on your lights, and enjoy the silky soft shadow quality!
#20 andrew ward
andrew ward
  • 269 posts
Posted 03 May 2015 - 09:22 PM
And do the umbrellas nestle nicely together?
Seems like theres be side spill.
I dig it but i cant see anyone letting me use it on one of my jobs. Super inflexible.
But its cool.
Also tagged with one or more of these keywords: dedolights
