Welding/Grinding/Metalwork Lighting Effect
Lighting Effect Welding Sparks Metalwork
7 replies to this topic
#1 Alan McIlrath
Alan McIlrath
  • 2 posts
Posted 08 May 2015 - 10:33 AM
Hi all,
I'm looking for some advice/ideas/thoughts on a lighting effect I'm trying to recreate.
I'm shooting a micro-budget short next week which features a scene of building/metalwork going on behind a closed door. I found a good reference for the effect I'd like to recreate (00.00-00.02):
https://www.youtube....h?v=G6JTi__Mtb8
One slight difference from the reference is the scene will be shot at night and moonlit. So far the only idea I really have had is to try a couple of blondes on dimmers and maybe add some sparks in post and let the sound design carry the effect. I'd be keen to hear if anyone else has tried this and what the outcome was.
For the shoot I'll have a 2.5k Par HMI, some Blondes, Red Heads, 650W Fresnel and some Dedolight 150W, unfortunately I don't have a welder!
Thanks in advance for any input.
Alan
#2 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 08 May 2015 - 10:45 AM
The flashing in the video reminds me more of lightning or an electrical arc flash than welding.  Welding, neither stick (arc), MIG or TIG,  will throw a big plume of sparks.  Oxy/Acetylene cutting torches do.  If that's the effect you want, an angle grinder applied with a heavy hand on a chunk of scrap steel will give you that look..
#3 JD Hartman
JD Hartman
  • 1809 posts
Posted 08 May 2015 - 11:50 AM
IMaybe all you do want is arc flash....never mind.  Could do that with a rented Magic-gadget box and a couple of lamp heads.
#4 Phil Rhodes
  • 12407 posts
Posted 08 May 2015 - 11:59 AM
You can always rent one of these, which I believe is more or less based around a welding set anyway:
#5 Alan McIlrath
Alan McIlrath
  • 2 posts
Posted 09 May 2015 - 04:04 AM
Thanks for getting back, JD, will try do some tests with a flicker box and couple of lamps. There may well be an angle grinder at location to try make some real sparks as well.
Phil, that thing looks amazing, would love to get a hold of one! Sadly all kit has been begged, borrowed and stolen, no money left.
Thanks, guys.
#6 Phil Rhodes
  • 12407 posts
Posted 09 May 2015 - 05:25 AM
You could always just get someone in with welding equipment. Given basic measures to protect the crew's eyes (look away, basically), it shouldn't be too big a deal.
#7 Brian Drysdale
  • 5343 posts
Posted 09 May 2015 - 06:22 AM
We used a welding kit for an electrical flashing effect on a short. If you know someone who owns a welding kit it would be a matter of persuading them to operate it to create the effect (unless a member of the crew knows how to operate one). The effect is much better in lower light levels. Try local engineering or car repair companies and give them a thanks to credit.
#8 JD Hartman
JD Hartman
  • 1809 posts
Posted 09 May 2015 - 06:33 AM
Are you looking for sparks or arc flash or both?  An angle grinder will deliver the sparks.  You wouldn't want someone using an electric welder on set, too much ultraviolet.  As I said, welding doesn't produce a shower of sparks unless it's a gas cutting torch.
Edited by JD Hartman, 09 May 2015 - 06:34 AM.
