Hot! Hot! Hot!
#1 Abby
Abby
Posted 17 May 2005 - 12:44 PM
I'm a New York based AC working on my first job in the west. We're in the desert in AZ. Any tips for shooting in heat that breaks 100 degrees? We're shooting Fuji 64D with the Aaton XTR. Any high-temp quirks you've experienced?
#2 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 17 May 2005 - 12:53 PM
Hi there-
I did a shoot in 120-degrees in New Cuyama, CA- keep the camera covered with a reflective blanket, our SR3 got too hot to touch! I was worried about the film (also fuji), but it pulled through just fine, maybe because we were only out there a day, and kept it in coolers.
you'll see your actors and others start to drop like flies if they don't keep a lot of water and shade available!
#3 Mark Sasahara
Mark Sasahara
  • 121 posts
Posted 17 May 2005 - 01:23 PM
You can use a space blanket with the silver side out as a camera cover. It's cheap and can envelope the whole rig and then be bungeed at the bowl of the tripod.
And yes, lot's of water and sunscreen. If you can have the grips or someone set up a 4x4, or 6x6 to shade the camera that will also be good.
If there's lots of blowing sand perhaps a haze filter might be good to protect the front element, maybe even a 2, or 2B to cut through some of the UV. Lot's of dust off and a couple of soft brushes.
Yeah, keep the film cool with ice packs in a cooler.
#4 Richard Boddington
Richard Boddington
  • 5508 posts
Posted 17 May 2005 - 06:31 PM
A big issue as well is the blowing sand and where it can end up.
On my desert shoot last year I was amazed at where the sand got into. Even tightly zipped camera bags had sand in the bottom of them.
R,
#5 J. Lamar King
J. Lamar King
  • 764 posts
Posted 18 May 2005 - 01:10 AM
I've got two 4x umbrellas that have shafts that fit into a grip head perfectly. I don't leave home without 'em.
