Slow - motion
7 replies to this topic
#1 Guy Meachin
Guy Meachin
  • 216 posts
  • U.K.
Posted 17 May 2005 - 08:34 PM
How can I get the best results on the XL2 for slow motion?
What shutter, frame mode, post production settings should I apply for best results?
Cheers
Guy
#2 Jay Gladwell
Jay Gladwell
  • 144 posts
  • Miami, FL
Posted 18 May 2005 - 06:05 PM
What you do in post will have a far greater impact than what you do while shooting. What NLE will you be using?
Jay
#3 Guy Meachin
Guy Meachin
  • 216 posts
  • U.K.
Posted 18 May 2005 - 06:53 PM
FCP 4.0 HD!
#4 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 18 May 2005 - 07:00 PM
It depends on how slow you want it. I've found a shutter speed slower than 75 staggers a little bit when you slow it down. Motion blur on top of motion blur. Shoot in progressive mode. And Final Cut HD is 4.5.
#5 Alvin Pingol
Alvin Pingol
  • 677 posts
  • California
Posted 21 May 2005 - 06:52 PM
Shoot in interlaced mode to capture the maximum amount of motion per second, and use a 180-degree shutter (1/100th or 1/120th-sec, depending on where you are). In post, bob-deinterlace (50i/60i to 50P/60P) the footage and set its playback rate to 24fps (or whatever you wish, however much you want to slow down the footage).
Motion rendering will be essentially equivalent to that of having shot film, or progressive video, at 50fps or 60fps, though you are likely to encounter "shimmering"; an artifact caused by the interpolation of alternating odd and even fields.
#6 robtags
robtags
Posted 27 May 2005 - 08:08 PM
Bit of conflicting info...
Alvin, what is meant by 'bob-deinterlace', could you elaborate? And also, does this all hold true for the XL-1?
#7 Alvin Pingol
Alvin Pingol
  • 677 posts
  • California
Posted 28 May 2005 - 08:26 PM
Bob deinterlacing is one of many types of methods used to convert interlaced footage to progressive. Unlike deinterlacing methods such as duplicate fields, interpolate fields, discard fields, and blend fields, all of which output a stream with the same framerate as the original file, bob deinterlace splits each frame into two, one consisting of just the odd fields, the other the even fields, and interpolates the missing lines. The output is a file with twice the framerate of the original, for each frame no longer consists of two fields (i.e. two moments in time) - they have been separated and given their own frames:
Input file, Interlaced, First four frames:
1) 1A+1B
2) 2A+2B
3) 3A+3B
4) 4A+4B
Output, progressive, First eight frames:
1) 1A
2) 1B
3) 2A
4) 2B
5) 3A
6) 3B
7) 4A
8) 4B
Starting to make sense? :)
And yes, since the XL1, as any other video camera, can shoot in interlaced mode, bob deinterlacing can be applied.
#8 Phil Rhodes
  • 12171 posts
Posted 29 May 2005 - 06:27 AM
A proper bob-deinterlace will interpolate out as much of the shimmer as it can. Virtualdub will do this for free.
Phil
