Tripods and the Eclair NPR
15 replies to this topic
#1 Brian Rose
Brian Rose
  • 896 posts
  • Kansas City area
Posted 19 May 2005 - 03:02 PM
After all the reading I have done about cameras, I would never have figured that tripods themselves could be so complex, multivaried and expensive. I am looking at getting an Eclair NPR, but I will also need a tripod, which leaves me at a loss. Does anyone know what sort of tripod is necessary for the NPR? Is it possible to get a nice basic one for cheap, as opposed to the ones at Visualproducts.com that go for thousands? I would appreciate any help you can give. Thanks!
Best,
BR
#2 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 19 May 2005 - 03:49 PM
The Eclair NPR weight is aprox. 20lbs.
So any good tripod that will hold over 20lbs is good
Try and get a good fluid head it'll be good for pans and tilts.
Here are some brands to research:
Satchler
Manfrotto
Cartoni
O'Connor
Miller
Panther
Good Luck
#3 Ian Marks
Ian Marks
Posted 19 May 2005 - 05:00 PM
The NPR is an odd shape and sits high on top of its motor. There were some tripod heads made specifically for the NPR which took this into account - you might luck out and find one of these cheap. Of course you can use a regular tripod head too.
#4 Jordan Brade
Jordan Brade
  • 57 posts
  • Los Angeles, California
Posted 20 May 2005 - 03:02 AM
I just received my Eclair NPR in the mail a few days ago. This will be my first experience with 16mm, but the second I saw the NPR, I knew I was in love. :P
I never realized how heavy a 20lb. camera would actually be until I tried lifting this thing on my shoulder and walked around with it for a bit. I'm going to need to go to a gym...
Just find a heavy duty tripod. The standard camcorder tripod will be crushed by this thing!
#5 andrewbuchanan
andrewbuchanan
  • 216 posts
  • Chapel Hill, North Carolina
Posted 23 May 2005 - 08:39 AM
Try the bogen 316 Ultra HD head on a set of 3191 sticks. The set-up is about as light as I would go for a loaded NPR. You can probably get one off ebay for under $1000 if you keep an eye out. I have used this support in the past and have been pleased with the results. It's no O'Connor Ultimate, but for the money it would be hard to beat.
#6 IvanKane
IvanKane
  • 35 posts
Posted 23 May 2005 - 01:06 PM
I'm a film student in London and I just got this 16mm Eclair NPR.
I have no idea how to make it work. I read the manual back and forth and still nothing happens except, yes I get a red light when I plug the battery, that's it.
Any idea of how to get this machine to work?
Another question?
What would be the best place in London to get your Eclair checked and maybe converted to S16mm?.
Would 13lb Bogen 501 Fluid head be way to weak for the Eclair?, maybe it would be 'just'OK. Thanks a bunch for a brilliant site...
#7 andrewbuchanan
andrewbuchanan
  • 216 posts
Posted 24 May 2005 - 08:17 AM
Forget the 501, it's WAY too small. My NPR weighs in at 30lbs with a full load and all the accessories (and that is with an Arri LW follow focus and Matte box). I wouldn't even consider anything that was rated below 25lbs.
#8 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 24 May 2005 - 04:21 PM
I have no idea how to make it work...I get a red light when I plug the battery...
Another question?
What would be the best place in London to get your Eclair converted to S16mm?.
<{POST_SNAPBACK}>
Well have you charged the battery?
The redlight probably is indicating a low battery output.
If you want to convert your NPR you should check out Les Bosher
http://www.lesbosher.co.uk/
You should really have known how to use the camera before you brought it
And you also should have known a place to get it serviced...
It is important camera buyers know their product before buying it...
Or you might run the risk of getting ripped off.
Eitherways
Good Luck
#9 IvanKane
IvanKane
  • 35 posts
Posted 27 May 2005 - 01:37 PM
I got the whole kit for free
Eitherways
Good Luck
<{POST_SNAPBACK}>
#10 IvanKane
IvanKane
  • 35 posts
Posted 23 September 2005 - 09:37 PM
<{POST_SNAPBACK}>
Thanks for your help.
I didn't buy it. Got it for free.
#11 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
  • Athens, Greece, London UK
Posted 24 September 2005 - 12:43 AM
Another question?
<{POST_SNAPBACK}>
Also the red light sometimes indicates a false pin in the current wich means that maybe u are giving power that has + to minus and opposite.
Dimitrios
#12 IvanKane
IvanKane
  • 35 posts
Posted 24 September 2005 - 11:00 AM
Dimitrios
<{POST_SNAPBACK}>
I got a new motor now :)
Is this tripod good enough for Eclair NPR?: http://cgi.ebay.co.u.....AMEWA:IT&rd=1
#13 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
Posted 24 September 2005 - 11:33 AM
<{POST_SNAPBACK}>
I am not sure if your eclair has a flat base, I remembered one that I was using that I am not sure if this was a market product or someone's patent.
If you don't have a flat base for eclair Npr, then the tripod u wanna buy won't do your job.
Also for me it looks amateur.
Try something like a sachtler 25 head for a start.
Dimitrios Koukas
#14 Robert Glenn
Robert Glenn
  • 247 posts
Posted 25 September 2005 - 04:07 PM
I went through this delima about a month ago. I ended up getting an oconnor 50D head and 25L carbon fiber legs. I think the only manfrotto head that would suffice for an NPR would be the 3274. That 116 head in the ebay listing that you mentioned might break with an NPR!
An Oconnor 50 is rated for 50 pounds, and has counterbalance springs, which is a must with an NPR. Just keep an eye on ebay auctions... Just don't get one with the 'pro junior base' which is the really wide base!
#15 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 26 September 2005 - 05:49 AM
Hi
The Ronford F7 head was developed especially for the NPR...because of its wierd centre of gravity problems especially when long lenses are fitted.
They are now top end equipment and very expensive...you may get a very old one second hand.
Look them up on the ronford website.
Cheers
Rob Spence
#16 IvanKane
IvanKane
  • 35 posts
Posted 05 November 2005 - 09:50 AM
Hi!
I have an old Miller fluid head tripod and I can't mount my Eclair NPR on it because the screw on the tripod is too small. I tried to use a converter but it just broke. I guess I need to change the screw but I don't know how. It seems that I will have to screw the head apart to change the screw but then again the screw is not just a normal screw. Any suggestions what I should do?
