To Push or Pull? Vision3 Question
push processing pull processing vision3 kodak film 16mm help question overexposed 500t
36 replies to this topic
#1 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 13 July 2015 - 12:44 AM
I shot a short roll of Kodak 500T (16mm). Upon finishing I noticed, much to my dismay, that the ISO on my light meter was set to 50. So, the fast film's exposure index is rated at 500T and I overexposed by how many stops? Can either push or pull (pull, right?) processing save this spool? The negative is probably pretty dense too, right? I saw a latitude test where film was overexposed by 5+ stops and it looked nice. Hoping there's a way to remedy this problem.
Edited by Luke Roberts, 13 July 2015 - 12:44 AM.
  • 19835 posts
Posted 13 July 2015 - 01:06 AM
You overexposed by 3 and 1/3 stops, which is savable assuming you exposed correctly for 50 ASA and didn't overexpose on top of the overall overexposure.  You may have some loss of detail in very light-toned objects though, hot highlights, etc.
You could have it pull-processed by 2-stops if you want, that would make the negative closer to normal density.  Trouble is that a lot of 16mm labs don't offer pull-processing, just push-processing, but these days with all film processing being somewhat special, maybe the lab would be OK with pull-processing it for you.  Otherwise, with normal processing, it will just be very dense -- it can be printed down, if printing, or it can be corrected in a telecine transfer, you just may see some noise in the whites.
#3 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 13 July 2015 - 01:18 AM
Spectra offer pull processing on 16mm film, but they have a 400' minimum. You can put your film on "standby" which means they wait for 300' other feet of film before processing the whole batch, but I can't imagine they would offer pull processing on that, since you'd probably be waiting a long time for someone else who also needed their footage pulled 2 stops as well. So if you have 400'+ of footage, that's probably the way to go, but it sounds like you probably shot 100', in which case, give them a call?
http://www.spectrafi...eo.com/Lab.html
#4 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 13 July 2015 - 01:51 AM
Thank you for the quick and informative feedback! Is this how you figure out the stop differential?
...50 100 200 400 (500) (600) (700) 800...
        1+   2+   3+   1/3    2/3    3/3    4+
I'm going digital intermediate with this footage, but I'd still like to get pull-processing done if possible.
Thanks! Yes. 100'. I've been meaning to try out Spectra, although at first I wasn't even sure if they were still in business (low-profile internet status I suppose)! I'm positive you guys have heard of this lab before; it's a great deal nearer to me than those long-standing SoCal laboratories (not that distance matters). On their processing form, you can choose Pull 2 from a drop down menu. I'm assuming that means pull-process by 2-stops?
#5 Jay Young
Jay Young
  • 485 posts
  • Lexington KY
Posted 13 July 2015 - 05:06 AM
I'd be interested to see the results of this!  Please post a frame grab or video link when finished.
#6 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 13 July 2015 - 08:54 AM
Correct about the stop differential. Each stop effectively doubles or halves the ASA.
#7 Leon Liang
Leon Liang
  • 90 posts
  • Sydney
Posted 13 July 2015 - 08:59 AM
Between 400 and 800 ASA wouldn't the third-stops be 500 and 640?
#8 David Mullen ASC
  • 19835 posts
Posted 13 July 2015 - 10:26 AM
Yes, 400 / 500 / 640 / 800 -- Luke had "+3/3-stops" before "+4-stops" which doesn't make sense, they are the same thing.
#9 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 13 July 2015 - 11:06 AM
Will do!
No, it doesn't. But using a comma without a conjunction doesn't make sense either.
Anyhow, thanks for the clarification.
Edited by Luke Roberts, 13 July 2015 - 11:07 AM.
#10 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 13 July 2015 - 11:47 AM
@David Mullen:
Sorry. That comment was rude of me.
Edited by Luke Roberts, 13 July 2015 - 11:49 AM.
#11 David Mullen ASC
  • 19835 posts
Posted 13 July 2015 - 12:03 PM
Thanks, and I'm sorry for not pointing out your math error more politely.
#12 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 13 July 2015 - 12:20 PM
Oops, I was only glancing at the full stops. Yes, all that everyone else said!
#13 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 13 July 2015 - 07:41 PM
I believe FotoKem does pull-processing, as well.  Not sure if their minimum footage is 400' or 200', though.
#14 Robert Houllahan
Robert Houllahan
  • 1586 posts
  • Providence R.I.
Posted 14 July 2015 - 04:46 PM
We do Pull Processing at Cinelab it's just a per foot charge of $0.10/ft over the normal developing cost. Pull Processing is running the developer faster so it's fairly easy to put the Pull onto the processor at the end of a normal run and adjust the speed for it.
I have seen 500t intentionally overexposed 5 stops for a look.
With a Pull -2 and a Data scan it should be recoverable to a normal look.
#15 Kenny N Suleimanagich
  • 900 posts
Posted 14 July 2015 - 04:56 PM
I recently did a +3 overexposure with a -1 pull, from Cinelab with a data scan, and it looked great. I was very happy with the results. You have a bit of space in the gamma to work with with a flat .dpx file.
#16 Josh Gladstone
Josh Gladstone
  • 323 posts
  • Editor
  • Hollywood
Posted 14 July 2015 - 06:34 PM
@Robert: That's clever. I did always wonder how a lab could push some footage without pushing the whole batch. It all makes sense now!
#17 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 15 July 2015 - 06:17 PM
I'm getting a data scan done. Any tips on coloring and exposure?
Thanks. Do you you have any samples or examples of Cinelab's work? Although I've already sent the film out to be processed and scanned with a Pull -2 on the aforesaid roll.
I wonder if ProRes 4444 will have the same amount of space?
Edited by Luke Roberts, 15 July 2015 - 06:18 PM.
#18 Robert Houllahan
Robert Houllahan
  • 1586 posts
  • Providence R.I.
Posted 16 July 2015 - 12:07 AM
I have been meaning to put up a specific scanner and demo page on the web site, as the only lab in the Northeast we are pretty busy and I haven't got to it.
Here is my Vimeo page and all of the film materials on my page were done at Cinelab
www.vimeo.com/lunarfilms
We don't release any clients film but it's in TV shows, Features and Ad work all over the world.
#19 Luke Roberts
Luke Roberts
  • 20 posts
  • Akron
Posted 23 July 2015 - 01:29 PM
There you go. Everything turned out nicely. I added a bit of contrast to it.
Thanks again, David.
Thanks for the info!
  • 2
#20 David Cunningham
David Cunningham
  • 1049 posts
Posted 23 July 2015 - 01:37 PM
Amazing! Try getting away with that in the digital world!
  • 1
Also tagged with one or more of these keywords: push processing, pull processing, vision3, kodak film, 16mm, help, question, overexposed, 500t
Opal
Opal
