Shafts of Light - M18's good for the job?
light shafts M18 Arri beam projection parabolic
#1 Chris Parente
Chris Parente
  • 2 posts
Posted 18 July 2015 - 09:19 PM
          Hey everyone,
     So for this low budget commercial I'm shooting, I'd really love to have a stronger light at a distance to get a "shafts of light through window" gag with haze.  It's just not in our budget so I'm trying to find the best way to get a large parallel beam into a small space (the room is only 15'x19') and I feel like the M18 could be a way to do this.  I'd also consider using a Joker Leko setup but I'm just afraid it won't produce as large or powerful of a beam as the M18.
      Arri describes the M18 as having the best aspects of a par and fresnel - personally I love this light and I've been able to produce some venetian blind gags in small spaces with it before.  I know an ordinary par wouldn't work at such a close distance.  My question is, do you think the beam of the M18 is parallel enough to make a gag like this?
Thank you,
Chris
  • 20182 posts
Posted 18 July 2015 - 09:41 PM
In a short distance throw I don't think the M18 is any better than another fresnel for parallel rays. I'd go for a Joker 800 Source-4 Leko if I want that Xenon beam look. But a Leko won't have the spread unless you cluster a couple of them for a series of parallel beams.
  • 1
#3 Chris Parente
Chris Parente
  • 2 posts
Posted 18 July 2015 - 10:25 PM
Thanks for the quick & informative response David, I was actually looking at your work from this thread about light shafts from a while back for some inspiration: http://www.cinematography.com/index.php?showtopic=34654
   You said the M18 wouldn't be any better than another fresnel for the job... could I take it then that it's also not necessarily any worse than another fresnel?  Or is that wishful thinking...
Edited by Chris Parente, 18 July 2015 - 10:31 PM.
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 18 July 2015 - 10:35 PM
Here's a "shaft of light" setup done with an M18 about 10' away from the window. A Joleko 800 would have a tighter beam with less punch so you could walk it in much closer to get more out of it. But in the end I think you want a unit with more output unless you can use a camera system with high ISO to compensate. Another idea is to put a 4x4 mirror where the M18 would go and pound the M18 into it to increase the distance for more parallel rays.
  • 2
Also tagged with one or more of these keywords: light, shafts, M18, Arri, beam, projection, parabolic
