Back Light Dimming in and out question.
trying to recreate a look
#1 Cristian Carceller
Cristian Carceller
  • 44 posts
  • Los Angeles, California
Posted 16 August 2015 - 01:45 PM
I am Shooting a rock band video and I am trying to see how this artist pulled off the dimming in and out of the two back lights used at 1:50 in this music video
Also I am wondering what sources these might be and how they rigged up two of them to dim in and out at the same time. I am trying to do the same thing but instead of just back light hitting the artist i want it to reveal and fade away the remains members of the band. i think this look is cool so i want try and throw my own style on it.
Anyone know what source this could be and how they rigged them up?
Thanks!!!!
Cristian
#2 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 16 August 2015 - 02:39 PM
Both lights (they look like parcans, so 1Ks) are on the same dimmer. You would need a 2K Variac dimmer as a minimum to handle the load. It's kinda tough to do quick up and down dimming on a Variac like that since it has a big and heavy knob, so maybe they used something like a Magic Gadgets 2K Quick In-Line dimmer.
#3 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 16 August 2015 - 08:20 PM
Or a 2k or 6k Lex Products electronics dimmer.  It has a slider.
#4 timHealy
timHealy
  • 1291 posts
Posted 16 August 2015 - 09:46 PM
You could use 500 watt par bulbs if one would want it to dim up faster. Also one could use a small dimmer pack and DMXit or small programmable board or laptop computer running dimmer software for repeatability. I'm not an expert at this but one could probably run a light board off midi signal from the track for perfect repeatability if it was needed.
Beware 2k Magic Gadgets running 2k's. I low they say 2k, but that load burns them up once in a while. A friend warned me about it. But I didn't believe it till I saw it happen.
#5 JD Hartman
JD Hartman
  • 1809 posts
Posted 17 August 2015 - 06:25 AM
The standalon Lex dimmer packs are DMX controllable.  http://www.lexproduc...ngle-dimmer-6kw
