Soft light on talent for night interior.
night interior lamps low-key
32 replies to this topic
#1 Haydn Michael John West
  • 25 posts
Posted 24 August 2015 - 04:57 PM
Hello,
Would any of you be able to suggest how to get some soft, flattering light on the face of the talent in an establishing shot of a room at night while avoiding spill. The lighting is motivated lamps but most areas will be allowed to fall away to near darkness. I've attached a low-resolution image of how I would like the room to look. Also when it comes to the close-up would any of you advise using a small booklight? Many thanks in advance for any responses.
Best regards,
Haydn
Edited by Haydn Michael John West, 24 August 2015 - 04:58 PM.
#2 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 24 August 2015 - 05:15 PM
Where will the talent be?  And will they be moving?
#3 Bradley Stearn
Bradley Stearn
  • 121 posts
  • 2nd Assistant Camera
Posted 24 August 2015 - 06:12 PM
Great question Haydn, I am following this thread as I too would like to hear some answers. Lets say the actor was sat down on the arm chair or at the table. If you wanted to enhance the soft/flattering light on their face, and you didn't want any spill, maybe a small light like a Dedo 150w just off frame, with some diffusion might do the trick?
#4 Haydn Michael John West
  • 25 posts
Posted 24 August 2015 - 06:16 PM
Hey Bill, the talent will be on the chair to the left and static. I thought about using a small Dedo too Bradley and if it looks good then its a nice fix. Now I'm thinking about putting a chimera above and flagging to the shape I want it. That seems to be the only way to get REALLY soft light cutting in unless others can suggest another way.
Edited by Haydn Michael John West, 24 August 2015 - 06:17 PM.
#5 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 24 August 2015 - 06:37 PM
I actually like the way the light is falling on the chair in that image.  What about putting a higher wattage practical in that lamp and just re-arranging it a bit to fall more on the talent?
#6 Miguel Angel
Miguel Angel
  • 895 posts
  • Spain / Ireland / South Africa
Posted 24 August 2015 - 06:38 PM
If you don't see the ceiling and have enough room you could always rig a china ball above the table and wrapped in black paper or black fabric so you don't let the light go to the walls.
If you want to soften it even more, you could always put a frame with diffusion below the china ball, providing you have enough room left of course.
As for the left - hand side, it looks like it is a small light, maybe it is a dedolight inbetween the hard and the soft edges as the shadow is hard but not as strong as it should be and there is a circle around the chair and you can see the penumbra.
For close - ups you could use a Rifa Lite, fantastic lights, come with a dimmer and with an egg crate, alternatively you can use a 1K / 2K fresnel / Open Face with depron on it.
Have a good day!
  • 1
#7 Haydn Michael John West
  • 25 posts
Posted 24 August 2015 - 06:41 PM
Thanks Miguel, good suggestions.
#8 Bradley Stearn
Bradley Stearn
  • 121 posts
Posted 24 August 2015 - 06:45 PM
Miguel could you explain more about using depron on an open face lamp please? I know depron as a type of foam, im assuming it's something else in the film world?
#9 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 24 August 2015 - 07:03 PM
Hey Haydon. so the picture you posted actually doesn't really use soft light much. I think often it is a misunderstanding that dim scenes seem softly lit. the practicals are pretty big here too they are doing a lot.
this is motivated with the two lamps and the main lamp is mimicked with a hard source from above maybe like 250 on the doors of the light or something but no big soft source's there.  there appears to be a second soft source in the room that is lighting the bottom right of frame with that table but its hard to tell in such a low res photo what is going on. There is also the window glow which is doing some stuff.
the thing about controlling soft light is you need bigger flags or more duv or w/e your going to use. One thing alot of people do is use china balls. the classic situation is a skirted china ball over the middle of a dinner table. but you can use that in any situation. Chimera's are also good but you may need to extend out pieces duvetine or flags somehow to control the light. This usually means rigging to ceilings in wide shots with ceiling spreaders or other tools like this.
I think a good thing that I have learned is not to be afraid to underexpose. Often times if you look at frames like your reference you'll find the whole thing barley touches 50IRE in scopes. so that means even your hottest parts of the frame may just be at your stop. This of course depends on style your going for, but something to consider.
for close ups you can do book lights but they hard to control. You might be better again with something like a large china ball, but really anything can work you just need a nice soft source that wraps. Honestly the light from a real lamp can be perfect size sometimes or a real lamp through some like a 4x4 of 216/250.
Edited by Albion Hockney, 24 August 2015 - 07:04 PM.
#10 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
This Depron was discussed in another theread recently.  It is extruded rather than beaded polystyrene.  So it won't fall apart in thin sheets.  It would be usefull to know what the light loss is with this material,  for a given thickness.  If we placed it in front of our meter,  what is the light loss?  it will probably vary according to the thickness and density.  Depron will be a brand name,  pretending to be a material,  in order to own that little niche in our heads.
#11 Miguel Angel
Miguel Angel
  • 895 posts
Posted 24 August 2015 - 07:04 PM
Of course, I think I might even post some photos during the week if I get a light where to put a piece of depron on.
Basically you have your lamp, you put two of the barns in the desired position and put a piece of depron inbetween, placing the depron with pegs in each of the two barns.
What I usually do is cutting the light from the two sides where the depron is not acting so you don't have unwanted light.
Depron will give you a super super soft light with a very tender texture, I don't know how to describe it better.
Have a good day.
#12 Bradley Stearn
Bradley Stearn
  • 121 posts
Posted 24 August 2015 - 07:07 PM
That explains it really well Miguel, thanks Gregg as well. So as an example, depron in front of a 2kw open face won't burn/melt?
#13 Haydn Michael John West
  • 25 posts
Posted 24 August 2015 - 07:10 PM
Hey Albion, thanks for taking the time to share your knowledge,I appreciate it!
#14 Miguel Angel
Miguel Angel
  • 895 posts
Posted 24 August 2015 - 07:11 PM
If you leave it there for 20 hours I suppose it will, eventually
However, I have used it a lot on 2K open face lamps and I have never had a problem.
Of course, it is something not a lot of people like but I do.
If you give me your address I can send you a small piece by post so you can ask around and see if you find it.
Have a good day.
#15 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 24 August 2015 - 07:14 PM
Bradley,
I've never used extruded poly for diffusion,  but I'm sure Miguel can give some guidelines. If Depron is what I think it is then it is quite sensitive to heat,  just like beaded poly.  My guess is that it will get hot and you will move it futher away.  But all this you can try for yourself in 5 minutes.
#16 Stuart Brereton
Stuart Brereton
  • 3482 posts
Posted 24 August 2015 - 07:53 PM
I wouldn't worry about soft light in the wide shot. Unless it's a top light (which isn't necessarily that flattering) you'll find it hard to get a large source near the actors without it destroying all the mood of the room. I'd light them with some small softboxes, or just diffusion on the barn doors of the lamp, and then get a more flattering source in there for the close-ups.
Should you use a small booklight? There is so much rubbish said about booklights. They are not any softer than any other diffused source. Softness comes from the size of the source relative to the subject. So, a 'small' book light is not going to be magically softer than a bounced lamp or a softbox, or a frame of similar size. Use what you have space and time for.
Depron has a nice quality of light, but it's expensive and it's almost impossible to find pieces larger than about 2' x 3'. There are many other ways to achieve the same aim.
#17 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 24 August 2015 - 08:07 PM
I'd go with something more directional than a China ball, maybe a small chimera with 40 degree eggcrate or so rigged just above the frame. Or a 4x4 Kino Flo with 216 on it. You want something relatively low intensity that falls off before it reaches the back wall. The more directional chimera or Kino combined with the high angle will help with that as well.
I agree with Stuart, a book light is going to be counterproductive in a small space like that where you want to avoid spill. I'd just bring in a 4x4 diffusion frame for the close up and maybe lower the unit if you have the time. Combine that with some passive bounce sources like muslin on the floor and a beadboard and you should be good.
#18 Stuart Brereton
Stuart Brereton
  • 3482 posts
Posted 24 August 2015 - 08:51 PM
The thing is that, in a wide shot, the viewer can't really distinguish between hard and soft light. So, as long as you match the angle and intensity, you should be able to light hard in the wide and soft in the tighter coverage.
#19 Miguel Angel
Miguel Angel
  • 895 posts
Posted 25 August 2015 - 02:04 AM
Stuart, it is interesting to know that Depron is expensive in USA, in Ireland you can find pieces of about 1.5 by 1.5 meters for €2!
Have a good day.
#20 Bradley Stearn
Bradley Stearn
  • 121 posts
Posted 25 August 2015 - 02:23 AM
It seems pretty cheap on this UK website: http://www.depron.co.uk/prices.html
