meter setting for canon XL1
#1 siddharth diwan
siddharth diwan
  • 80 posts
Posted 22 May 2005 - 06:24 AM
I'm shooting on Canon Xl1 with frame rate 24p mode, what meter settings do i need to do for that.
#2 Josh Hill
Josh Hill
  • 258 posts
  • New York, NY
Posted 22 May 2005 - 09:56 PM
You cannot be shooting 24p on an XL1. If you're shooting in frame mode you're shooting 30P, but it's really not even real 30P if I remember correctly.
#3 Ed Moore
Ed Moore
  • 54 posts
  • UK
Posted 22 May 2005 - 10:11 PM
Or if it's a PAL XL1, frame movie mode would generate 25p.
But Josh is right, it's not "proper" progressive scan. I defer to the rather wonderful Adam Wilt:
These cameras get their "proscan" images not by truly perfoming progressive readout on the chips, but rather by offsetting the green CCD's read timing by one scanline during readout -- vertical pixel-shift, if you will. In essence, an even field from R & B CCDs is blended with an odd field from the G CCD, giving you a frame that has the scanlines for both fields captured at the same instant in time. This gives a definite improvement over mere field-doubled "frames", but it's not as sharp vertically as true proscan. Each "scanline" is actually composed of two scanlines from each chip, so there is some softening vertically; also, the effective chroma resolution is halved vertically.
As for the meter readings it's difficult to say exactly but I have heard figures bandied around for the XL1 with 0db gain being roughly equivalent to ISO 160 to 200. That makes a sort of sense to me as I know the F900 with it's larger CCDs reads out at 320.
If you have access to a really well lined-up monitor and an 18% reflectance grey card, you can work it out for yourself. Will post how if you like.
#4 Josh Hill
Josh Hill
  • 258 posts
  • New York, NY
Posted 23 May 2005 - 03:05 AM
160 to 200 is way low, I think. All of the numbers I've seen tend to say the XL1(s) is up into the 500-800 range and possibly higher (depending on each individual camera). I believe I read, once, that it was even 1600.
But of course, I could be wrong (and so could the dozen of people writing articles postulating on the ISO rating of the XL1(s).)
#5 Mike Donis
Mike Donis
  • 69 posts
  • Toronto, Ontario, Canada
Posted 23 May 2005 - 10:50 AM
When shooting video, it rarely matters to have a light meter on set. Because the output is at full quality, what you see is what you get - the zebra settings are your biggest exposure determining tool.
#6 Sampsa Huttunen
Sampsa Huttunen
  • 5 posts
  • Helsinki, Finland
Posted 08 November 2005 - 06:39 AM
I shot a documentary with Panasonic AG-DVX100A and Canon XL2 in 25p mode and found that XL2 needs more light than DVX100 which is around ISO 320.
