Rain Cover
Rain Camera protection raincoat
#1 Ivon Visalli
Ivon Visalli
  • 34 posts
Posted 28 August 2015 - 12:38 PM
I'd like to know your thoughts on rain coats for cameras.  Do most of you keep some sort of rain cover in your kit?  Do you find yourself shooting exteriors in the rain often or is it a rare thing?  What do you think is important to look for in a rain cover?
Thank you.
#2 Miguel Angel
Miguel Angel
  • 900 posts
  • Spain / Ireland / South Africa
Posted 28 August 2015 - 01:28 PM
Hi!
I'm in Ireland and it rains a lot, you can have all four seasons in just 12 hours
Hence, we have rain covers for the cameras which are actually very simple.
1) Get a long piece of a transparent plastic sheet (usually there is one side which is open and the other three are closed)
2) Put it over your camera with all the accessories that you want to use.
3) Cut a little hole for the viewfinder and maybe the card reader (although I don't like that as there are more chances for the water to enter)
4) Use velcro and more plastic to create flaps for those holes.
5) Cut a hole where your mattebox is.
6) Put velcro around the hole so it can be attached to the mattebox.
7) Put velcro in the open part so you can close the plastic sheet.
And that's all, a fantastic rain cover!
Have a good day!
#3 Ivon Visalli
Ivon Visalli
  • 34 posts
Posted 28 August 2015 - 01:37 PM
Miguel, thank you so much for the response.  If you get the chance, I'd love to see a photograph of your cover, especially detail around where you are attaching the viewfinder and matte box.
#4 Miguel Angel
Miguel Angel
  • 900 posts
Posted 28 August 2015 - 10:27 PM
No worries Ivon,
If I find the one that I keep at home (I'm moving houses so it could be with the gear that I moved already) I'll post a photo during the weekend.
Have a good day!
#5 Kyryll Sobolev
Kyryll Sobolev
  • 86 posts
  • Toronto
Posted 29 August 2015 - 04:55 PM
we use 2 types of rain cover
1. a clear garbage bag,
cut open one of its sealed sides, but leave a little bit at the corner
then use binder clips to clip the flat end (the cut open end) to the matte box
if needed, you can cut a hole for the cinetape,
but the bag will cover the operator as well, or leave him uncovered if that's their preference
this is also useful for blood squibs or any crud, because you throw away the bag after
2. a modified shower curtain - i've attached a picture of what i used
same thing as a garbage bag, but the plastic is heavier
it's more suitable for a dolly or stationary set up, because the operator and the AC are covered nicely
some people may not like the magnets or the metal grommets that come with the curtain, so use them scissors
#6 Ivon Visalli
Ivon Visalli
  • 34 posts
Posted 29 August 2015 - 05:00 PM
Thank you, Kyryll.
#7 Miguel Angel
Miguel Angel
  • 900 posts
Posted 01 September 2015 - 08:19 PM
There you go!
No need for more pictures now! :)
Have a good day!
#8 Michaela Angelique
Michaela Angelique
  • 2nd Assistant Camera
Posted 14 September 2015 - 11:18 PM
I am Los Angeles based AC.
I do keep my rain cover on my kit, but LA does not rain alot, I usually keep my gears simple and leave it at home.
I will bring it over if I know we would deal with special effects, it comes very handy.
I personally don't like camera rain covers specifically made for camera where rental houses usually have, they are not convenient, too many unnecessary velcros, not easy to wrap and unwrap.
When I travel out of state, where usually it rains alot more than LA, I'd bring it on my kit.
I always like clear plastic, you can see the buttons on camera.
#9 Ivon Visalli
Ivon Visalli
  • 34 posts
Posted 14 September 2015 - 11:27 PM
Hi Michaela,
Thank you for that information.  I agree, I don't like the manufactured rain covers and would prefer something simpler.  I also work in Los Angeles, so have had very little use for one.  Even when I worked in NY, we moved to a cover set on the rain days we had (though a tarp was used to cover camera and gear if it ever drizzled).  I appreciate your tip about using clear plastic, thanks.
Also tagged with one or more of these keywords: Rain, Camera protection, raincoat
