1.33:1 and 4:3 are same aspect ratio?
#1 L K Keerthi Basu
L K Keerthi Basu
  • 128 posts
  • india
Posted 29 August 2015 - 11:15 AM
Dear friends,
 My short film Director is very much interested to shoot his short film in 1.33:1 ratio. We are planning to shoot in Red Dragon, some of my friends came up with a doubt that 4:3 and 1.33:1 are not the same aspect ratio and there will be a project issue will be there. Please clarify my doubt i can't able to sleep.
  • 20164 posts
Posted 29 August 2015 - 11:39 AM
This is just basic math, not cinematography.  4:3 and 1.33:1 are the same ratio of width to height, just divide 4 by 3 and you get 1.333333.... so it's the same ratio just expressed differently, 4:3 expresses it in whole numbers, 1.33 : 1 expresses it by keeping the vertical at a value of "1" and letting the horizontal not be a whole number.
This is a holdover from video versus film -- video aspect ratios are expressed in whole numbers (4:3, 16:9) and film aspect ratios are expressed with the vertical as a single unit, so 1.33 : 1, 1.85 : 1, etc.
Projection issues are a whole other thing though, you'd have to figure out how you were going to screen a 1.33 : 1 image -- probably with black borders on the sides of a 16:9 HD file or a 2K DCP.
Or you'd be making a transfer to 35mm for projection on a print, but if you have sound on the print, the actual projection aspect ratio would be 1.37 : 1 Academy and you'd have to make sure your theater could screen the Academy print format, otherwise you may have to transfer the 1.33 : 1 image with a windowbox within 1.85 : 1 print area so that a theater set-up to project only 1.85 flat or 2.40 scope could show it properly.
#3 L K Keerthi Basu
L K Keerthi Basu
  • 128 posts
  • india
Posted 29 August 2015 - 11:47 PM
Thank you David, my final projection format is going to be both in 16:9 HD and 2K DCP.
