Help with Leicina Super - no power
Leicina
9 replies to this topic
#1 Simon Lucas
Simon Lucas
  • 100 posts
  • UK
Posted 31 August 2015 - 04:55 PM
My Leicina Super shows no sign of power.
It was shooting. And then stopped.
I checked the power window - no power - there had been earlier. Then checked the batteries with voltmeter.
No zoom, no shutter, no auto-exposure.
Checked batteries are seated and cleaned contacts.
Any ideas please?
#2 Carl Looper
Carl Looper
  • 1431 posts
  • Digital Image Technician
  • Melbourne, Australia
Posted 31 August 2015 - 05:08 PM
My Leicina stopped running quite recently as well. Perhaps there is some built in switch in all Leicinas that was set to switch off this year. :)
C
#3 Simon Lucas
Simon Lucas
  • 100 posts
  • UK
Posted 01 September 2015 - 04:07 AM
Yes - either that, or circuits/components die.  :)
I'm going to ask a guy called Eckhard. I found his name on filmshooting.com, which I remembered that I have also been a member of last time I needed to talk about Leicinas.
#4 Martin Baumgarten
Martin Baumgarten
  • 212 posts
  • Plattsburgh, New York U.S.A.
Posted 12 September 2015 - 01:07 AM
So very often the weak link in the LEICINA Super is the power supply.  I know you said you cleaned it and checked the contacts...however....the design of it is poor in some ways, and even when all seems fine, it still is not supplying power to the camera once you install it on the back.  Make sure the camera is in the off position prior to installing the power supply block.  Double and triple check the metal finger blades to make sure they are clean without any tarnish on them, as well as the recepter nibs on the camera body.  Then try it again and if still not running after turning the power switch on, try moving the power supply block about a little bit to see if that gets the camera running. If so, the stupid block is the culprit as it so often is on these fine cameras.  Why Leica went with this design, who knows, but it's a common problem.  Good luck, hope you can get your camera up and running again!
#5 Simon Lucas
Simon Lucas
  • 100 posts
  • UK
Posted 20 September 2015 - 05:11 AM
Martin, thank-you for your suggestion. I got delayed sending the camera off. And as it will now go this week, I think it is a good idea to follow your suggestions before I send it.
#6 Simon Lucas
Simon Lucas
  • 100 posts
  • UK
Posted 20 September 2015 - 04:40 PM
Martin. I forgot to say that I have also tested the camera using the external power supply/remote box. That did not work either, but I reloaded the battery compartment, cleaned the contacts. Still nothing, so it's going off to Germany.
#7 Martin Baumgarten
Martin Baumgarten
  • 212 posts
Posted 21 September 2015 - 02:00 PM
Hi Simon, a few last things to try:  try all camera release switches, the top one, the cable release, try moving the power switch to off and on a few times (all assuming that the power supply is correctly hooked up of course), and while even holding the main run switch to on, try thumping the camera on the side a few times, use a towel around your thumping hand.  Sometimes it's just something so minor that if you can get the camera to make a connection and run, and then run it for a few minutes and switch it on and off after she comes back to life, that is all it might take. Good luck either way.
#8 Martin Baumgarten
Martin Baumgarten
  • 212 posts
Posted 22 September 2015 - 09:44 AM
One last simple reminder here.....have to ask is sorry.  Did you try to operate the camera making sure there's a cartridge inside?  The LEICINA will not run without a cartridge inside as there's a small switch it pushes inward when a cartridge is inserted.  You can defeat this using a small piece of wood, some plastic and tape, or an old junker cartridge.  Many that aren't familiar with these cameras do not know about this, since the majority of Super 8mm cameras will run without a cartridge in them.
#9 Carl Looper
Carl Looper
  • 1431 posts
Posted 23 September 2015 - 06:17 AM
I found the problem with mine (it's a Special rather than a Super). On close inspection I found one of the batterys in the battery pack wasn't connecting to it's contact. A tiny piece of plastic that would otherwise hold the contact in place had snapped off. Removing the battery would move the contact back into it's correct position. Inserting the battery again would move it back out of position.
C
#10 Simon Lucas
Simon Lucas
  • 100 posts
  • UK
Posted 23 September 2015 - 04:39 PM
Martin. I do still have the cart in. But nice to know about that switch.
Carl. I'm not aware of the contacts being dodgy. The thing you describe with the metal contacts, is though, what has happened inside my remote control box, the ST-1. I will look at that, though. BTW, I did test the voltages coming out of the battery compartment. There seem to be two different sets of circuits in that box. I could not quite understand why, but I was getting voltage from them.
