A slightly amateurish question on lenses...
10 replies to this topic
#1 Nguyen D. Nguyen
Nguyen D. Nguyen
  • 52 posts
Posted 23 May 2005 - 01:12 PM
I'm a bit of a rookie when it comes to the arri 2c (though doing a lot of research on it). My question was about the lens mount on the 2c. I know it can be converted to a PL mount, but as for the turret, what types of lenses will fit on them? Are they readily available anywhere?
Suggestions? Resources? Opinions?
  • 20068 posts
Posted 23 May 2005 - 01:38 PM
I think to convert it to a PL-mount, you'd be disabling the 3-lens turret feature, permanently probably. I'm not sure, but I believe the turret uses Arri Standard mounts, so you'd have to buy old (smaller) lenses with that mount if you still want to use the turret.
Basically Arri cameras and lenses had (1) Arri Standard, then (2) Arri Bayonet, then (3) Arri PL (Positive Lock) mounts, each bigger and sturdier than the last to handle bigger & heavier lenses like zooms.
#3 Nguyen D. Nguyen
Nguyen D. Nguyen
  • 52 posts
Posted 23 May 2005 - 01:43 PM
<{POST_SNAPBACK}>
Thanks for the information, David. Are there any specific advantages to using lenses of certain mounts, and the Arri Standard lenses ... are they plentiful or have they gone near-completely obsolete?
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 23 May 2005 - 01:54 PM
All modern lenses come in PL mounts: Zeiss Master Primes and Zoom, Ultra Primes, Super Speeds, Cooke S4s and Zooms, Angénieux Zooms, Hawk Anamorphics, Elite Anamorphics, etc... If you want good glass you need a PL mount.
#5 Nguyen D. Nguyen
Nguyen D. Nguyen
  • 52 posts
Posted 23 May 2005 - 02:01 PM
All modern lenses come in PL mounts:  Zeiss Master Primes and Zoom, Ultra Primes, Super Speeds, Cooke S4s and Zooms, AngĂ©nieux Zooms, Hawk Anamorphics, Elite Anamorphics, etc... If you want good glass you need a PL mount.
<{POST_SNAPBACK}>
Hm. Can you give me a rough idea of how much the conversion costs?
#6 Sam Wells
Sam Wells
  • 1751 posts
Posted 23 May 2005 - 02:14 PM
Early turret models were 3 Std mounts, later they had 1 Bayo mt and 2 Std - those cameras were properly called 35IIC/B - just like the 16mm cameras with one bayo on the turret (16S/B; 16M/B).
Quite a few were modified to be "Hard Front" which was a single BNCR mount. Find one of them and some of the work is done although I'd suspect most of the Hard Front's have since been converted to PL by now.
-Sam
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 24 May 2005 - 07:32 AM
-Sam
<{POST_SNAPBACK}>
From the prices i've seen its slightly more expensive to convert from BNCR hardfront to PL Hardfront! than from turret to PL!
Stephen
#8 Nguyen D. Nguyen
Nguyen D. Nguyen
  • 52 posts
Posted 10 June 2005 - 05:30 PM
Stephen
<{POST_SNAPBACK}>
Hey all, I just have a question.
I am about to get my arri iic with variable shutter, pl mount and a cp crystal motor and what I'm concerned about is the PL mount. Out of curiosity, is it limited to only modern glass, or does it allow you to take any of the other lens mounts as well?
I'd just like to try some for tests, so I need to know if the pl mount can accomodate any other style lenses other than just pl-mount lenses. Would I need an adapter of some kind if it doesn't?
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 June 2005 - 03:57 AM
<{POST_SNAPBACK}>
Basically Yes. However you can get adapter for older Arri mounted lenses. A Nikon adapter is available but you cannot focus at infinity, so just macro!
Stephen Williams Lighting Cameraman
www.stephenw.com
#10 Nguyen D. Nguyen
Nguyen D. Nguyen
  • 52 posts
Posted 15 June 2005 - 09:08 PM
www.stephenw.com
<{POST_SNAPBACK}>
Would you happen to know where to get this adapter? My arri ii c-bv has a pl mount, which is really good, but I like to have options (cheaper options for certain situations) at my disposal.
#11 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 July 2005 - 07:52 AM
<{POST_SNAPBACK}>
try Les Bosher www.lesbosher.co.uk
Stephen
