Ideal reflector for max output from E27 (household socket) fluo bulb?
cheap
#1 Salil Sundresh
Salil Sundresh
  • 101 posts
  • 2nd Assistant Camera
Posted 24 September 2015 - 05:13 AM
I received a couple of those giant 5600k CFL bulbs recently for free and they are rated >90 CRI, so I thought maybe I could use this for some small setups where a little extra daylight fill is needed and I'm out of lights.  Does anyone know what sort of fixture/reflector design would provide maximum light output for a 150w E27 fluorescent bulb?
EDIT: I think this is what I’ve got:
Edited by Salil Sundresh, 24 September 2015 - 05:22 AM.
#2 Adrian Sierkowski
  • 7480 posts
Posted 24 September 2015 - 02:02 PM
Wescott and SmithVictor make some stuff.
If you wanted to get crazy you could get an ArriMAX reflector I suppose and fab up a system yourself-- but in 100% truth the marginal gains probably wouldn't be worth it if you're just looking  for a little daylight fill.
I think the name of the Wescott thing is the Octolight-- it'll take 8 bulbs in it (dunno if all those will fit) with a beauty dish like attachment and the ability to throw a silk over it.
It's something I also keep meaning to use with my Cree bulbs for much the same reason.
#3 Adrian Sierkowski
  • 7480 posts
Posted 24 September 2015 - 02:03 PM
Though, p.s. according to the site you listed, those are 240V lamps and won't work properly in 120V outlets.
#4 JD Hartman
JD Hartman
  • 1786 posts
  • Edison, N.J. U.S.A.
Posted 24 September 2015 - 06:09 PM
The six lamp version of the washtub: http://www.bhphotovi...t_Kit_with.html
#5 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 24 September 2015 - 09:09 PM
Salil,
I had a fixture with those large spiral CFL bulbs in them.  You might want to calm your expectations for them.  When I measured the bulbs they were actually about 4500K-ish and had a strong green bias.  So do test them before you expect the bulbs to actually balance well with "daylight".  ...but hey, they come out of a no-name company in Shenzhen so you can absolutely trust them, right? :)
Stuart
#6 JD Hartman
JD Hartman
  • 1786 posts
Posted 25 September 2015 - 05:38 AM
The fixtures themselves aren't very rugged, they are intended more for (photo) studio use.  Worked with them on a music video and yes, they are little more than a thin stamped metal washtub with sockets and a shower cap for diffusion.  You really would do better to build your own lights to your specs., as other have done before.  Several very clever fixtures are described and pictured in the Harry Box lighting book.
Edited by JD Hartman, 25 September 2015 - 05:46 AM.
  • 1
