4:2:2 10bit SDI recorders - atmos vs ?
#1 Albion Hockney
Albion Hockney
  • 486 posts
  • LA
Posted 29 September 2015 - 08:57 AM
I am thinking about buying a Sony F3 for some personal work as they are so cheap right now. the Internal 8bit 4:2:0 has always been a turn off and SxS is expensive so I was thinking of getting a monitor recorder to at least get 10bit Pro Res from it.
There are a few of these recorders out there - Atomos Blade, Ki Pro Mini, Odyssey 7 was wondering if there is any real difference in picture quality as the Atmos blade is $500.00 cheaper then anything else. Anyone use/have issues with the Atomos?
#2 Phil Rhodes
  • 12283 posts
Posted 29 September 2015 - 11:08 AM
Odyssey does somewhat more, but unless you specifically need the toys, Atomos is fine. Also the display is brighter, and full HD res.
The screen on one I had on approval cracked just by rubbing some grime off, but I suspect that's a one-off.
