"The Revenant" Visual Style and Cinematography
10 replies to this topic
#1 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 15 October 2015 - 05:41 PM
Hey Guys,
So I am shooting a project in Wyoming. It will be in a variety of environments (mostly forests and mountainous locations). I want to have a similiar "look" (although different to) "The Revenant". I know that mostly natural light was used, and I am in the same boat due to traveling restraints with gear. It will mostly be a guerilla-esque production, although it is narrative. Does anyone have any tips for me in terms of what techniques to use when shooting in snow/wildlife conditions?
I was thinking to mostly shoot early morning with an overcast sky, but wanted to hear your (professional) take on how I should have my set-ups. Thanks for your time.
P.S. - Bounce Boards for lighting? I noticed that "The Revenant" looks pretty amazing for only using natural light. Most of the trailer had a great lighting ratio on the character's faces.
#2 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 15 October 2015 - 05:42 PM
If you haven't seen the teaser trailer:
There is also the newer trailer if you want to see that also:
#3 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 17 October 2015 - 05:43 PM
Does anyone have any tips to help? Thanks.
#4 David Mullen ASC
  • 20468 posts
Posted 17 October 2015 - 09:03 PM
As you said, it's mostly about shooting in the best natural light for the look you want, so I'm not sure what else to tell you, other than the obvious (the movie has a cool cast and uses a lot of wide-angle lenses following the action up close with minimal cutting, but you can see all of that in the trailer.)
It helps to shoot on a wide dynamic range camera like the Alexa to handle the extreme contrasts.
  • 1
#5 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 17 October 2015 - 09:44 PM
Thank you so much for your response; it means a lot. I will be using a Ronin 3-Axis gimbal and a RED DRAGON. The Ronin will be used for some long tracking shots through the forest; some while on the back of an ATV (4-Wheeler). Other gear includes a drone for aerial footage and a shoulder rig/ tripod (more obvious options) for the rest.
Your advice helped!
#6 Robin R Probyn
Robin R Probyn
  • 2613 posts
  • Tokyo
Posted 18 October 2015 - 02:18 AM
Sorry maybe really obvious .. Ronin /Movi gets very heavy quickly being held out in front of you..  a lot of people are now using them in conjunction with an easyrig.. who now make an extended arm for the use.. might help your operator if you have long takes..
  • 1
#7 Miguel Angel
Miguel Angel
  • 896 posts
  • Spain / Ireland / South Africa
Posted 18 October 2015 - 05:54 PM
Chivo and Alejandro are very adamant about when to shoot so make sure that you schedule your shoot around the time of the day that you need (if you can)
They also use negative fill and that is something that you see on actor's faces.
It helps creating contrast ratios on their faces or on any other object.
Have a lovely day.
  • 1
#8 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 18 October 2015 - 06:56 PM
I appreciate your input, and I will look into that. Thank you!
#9 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 18 October 2015 - 06:57 PM
Have a lovely day.
Thanks for the lighting tip. I will definitely be using your suggestions. Have a great day yourself, good sir!
#10 Matias Nicolas
Matias Nicolas
  • 192 posts
  • Buenos Aires, Argentina
Posted 23 October 2015 - 10:37 AM
Avoid shooting midday, perhaps you can rehearse the shot and shoot  in the best moments of light, in the extremes... there you'll have a very nice light...
  • 1
#11 Shaeden Gallegos
Shaeden Gallegos
  • 26 posts
Posted 23 October 2015 - 11:47 AM
Thank you for the advice. That sounds like a very good plan. :)
