This clearly has some strong filming applications
lighting gear diy cheap
#1 Grégoire Bélien
Grégoire Bélien
  • 5 posts
  • Paris
Posted 26 October 2015 - 01:30 PM
I've been following this guy's videos for a while now and he's built a few things such as lighting gear for very cheap but nothing I had never seen.
In his last video he shows how to build a light panel that aims to simulate a window, from old laptop screen.
I really think that this is something that could have many applications for filmakers on a budget.
The result seems very soft and close to what you could obtain with very expensive gear.
Maybe there is another type of DIY gear that is close to this one but anyway, this is the first time I see something like that and I think it's awesome !
  • Capture d
#2 Tyler Purcell
Tyler Purcell
  • 4463 posts
Posted 26 October 2015 - 05:16 PM
Pretty sweet. Put that sucker into a nice wooden window frame and it may work nicely. I'd also put a light diffusion curtain or something in front of it so the light isn't so hard.
  • 1
#3 Phil Rhodes
  • 12406 posts
Posted 26 October 2015 - 06:59 PM
What you're actually getting out of that is something almost exactly like this, which can be bought fairly cheaply and in bulk if necessary. The expensive movie version of this is the Arri Versatile, which is exactly the same thing, just with more carefully-selected LEDs. The low-cost LED ceiling panels were used as practicals on the TV series Critical, built into the set, where they were deliberately selected to provide a cold, cyanish glow in the background. Versatiles were used as properly coloured keys.
The problem with the cheap ceiling panels and recycled monitor backlights is that the colour rendering will be absolutely horrible. Office lights are built for maximum output, not good colour rendering, and monitor backlights are designed to match the dyes in the display panels they're used with. Neither is likely to produce colour suitable for use as a key light, although I'm tempted to grab one of those low-cost two-foot-square things and see if it can be pressed into service, perhaps with better LEDs.
The other problem is that none of this edge-lit panel tech, no matter how good the LEDs, is really all that efficient. The diffusion required to create a clean rectangle of light from an edge lit device results in a lot of absorbtion in the acrylic panel itself. Even though it's optically quite transparent, the light has to go through whole feet of it, and many lossy bounces, to get to the middle.
It's interesting and has application because it's very shallow - the ceiling panels are under half an inch thick. But it's not really the best approach imaginable.
  • 1
#4 Grégoire Bélien
Grégoire Bélien
  • 5 posts
  • Paris
Posted 28 October 2015 - 10:03 AM
Thanks for your comment ! I'll definitely check if I can find the type of LED used or the colour spectre of some old LCD screens.
