Daylight Balanced Flourecent bulbs
#1 alchemistarmada
alchemistarmada
  • 1 posts
Posted 25 May 2005 - 06:54 PM
I'm building a cheap lighting rig and i'm gonna use flourecent bulbs and I have heard that if Daylight balanced flo bulbs are used on tungsten stock the light has a blue hue, is this true or is that true with daylight film or is it a daylight balanced halogen bulb? Think a cold lifeless blue, if I have to buy gels that's fine, if so, any sugestions on a good place on the net to buy and what kind? I'll be using s-16 fuji 500 tungsten
#2 Alvin Pingol
Alvin Pingol
  • 677 posts
  • California
Posted 28 May 2005 - 07:19 PM
If you're using tungsten-balanced stock then yes, daylight balanced flos (daylight balanced anything) will render a blue bias. Keep in mind, however, that the average fluorescent tube will also render a green shift on film, something you may want to compensate for by using CT MinusGreen/Magenta gels or appropriate magenta filtration.
Hope this helps!
#3 oscar jimenez
oscar jimenez
  • 317 posts
  • PANAMA, REPUBLIC OF PANAMA
Posted 30 May 2005 - 10:34 AM
If you plan using HMI's also, and if you are going for telecine, you can use a home made thermo colorimeter to check by eye How things are. Use a withe bond paper sheet and then decide if you should Gel your HMI's with plus green. Id rather add green or magenta to my lamps rather than to cover 10 fluorescent lamps on an office or Hallway. Then suppress green excess or magenta excess on Trnsfer
#4 David Mullen ASC
Posted 30 May 2005 - 10:50 AM
There are tungsten-balanced tubes if you don't want that blue-ish look.
In terms of the greeness, pick a tube with a high CRI value, above 90. The higher the number, the less green.
#5 oscar jimenez
oscar jimenez
  • 317 posts
Posted 30 May 2005 - 12:15 PM
I have some small sort of 42 inch tubes "home flos" that are color corrected Sylvania makes bulbs balanced for 3500k the code is: F17T8/T1735
Good luck. And if you are using this ones on Tripods, try to use ballast off lamp, makes lamp a little bit heavy.
