what are the RET/SYNC IN and TC I/O ports on the back of a camera
timecode gemlock ret/sync
#1 davide sorasio
davide sorasio
  • 93 posts
Posted 30 October 2015 - 11:37 AM
Hi everybody, I'm having issues understanding how time code works and what are the ret/sync and TC I/O bnc ports on the back of some cameras like the Amira for example.
I hope somebody can give me some clarification!
Thanks in advance!
#2 Phil Rhodes
  • 12407 posts
Posted 30 October 2015 - 11:56 AM
"Ret" probably means return video. It's often displayed in the viewfinder when the "ret" button on an ENG-style lens is pressed. It's used so the operator can check whether their picture is being used in a live situation, or to adjust framing with respect to the picture that is being used to ensure it cuts.
Sync is a video signal used as a timing reference for the camera, so that it can be frame synchronised with other equipment. Again, mainly something you'd use on live or studio work, but there are probably reasons to frame sync cameras on drama.
Timecode in and out are actually audio signals, although they're often on BNCs. If you actually listen to it, it's a sort of raucous buzzing sound which is used to encode the timecode as digital information. It was originally done this way so it could be recorded onto spare audio tracks, although modern equipment tends to generate the audio signal on the fly based on digital information in the frame data.
Hope that helps
Also tagged with one or more of these keywords: timecode, gemlock, ret/sync
