Zoom Aid
#1 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 01 November 2015 - 03:59 AM
Hello,
So I am shooting a one take and my director insists on multiple zooms being used throughout the shot.
The lens of choice is the Red Zoom [18-85 mm].
However I have noticed that pulling off smooth zoom by hand is head ache.
Is there any rig that helps in zooming in and out ?
Thank You
#2 Miguel Angel
Miguel Angel
  • 895 posts
  • Spain / Ireland / South Africa
Posted 01 November 2015 - 05:29 AM
Hello Vivek,
What you might want to use is a device called Microforce Zoom Control, made by Preston.
http://prestoncinema...ucts_micro.html
It is very easy to use and you usually attach it to the handle / arm of the head via an accessory which is usually included in the kit (O'connor or any other head).
You can select the zoom speed and it has a slow stop which is very handy to make smooth stops.
Have a good day!
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 01 November 2015 - 10:29 AM
Miguel is on it. Also, when you rent the Microforce, be aware that there is a newer digital version and an older analog version. Both work fine, but you can't use a digital motor with an analog Microforce so test that it works before you leave the rental house.
You also have to supply 12v power the Microforce, usually from a camera accessory port or the d-tap on the battery plate. Definitely specify to the rental house which camera and method of power you will require so that they can supply the appropriate power cable.
#4 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 02 November 2015 - 12:36 AM
Thank you Satsuki. Helpful as always this forum has been for me :)
