Super Cooke Lens
#1
Posted 03 November 2015 - 06:17 AM
I am shooting a low budget psychological thriller. With our budget I have the option of the high speed f1.3 Zeiss or the Super Cooke. Shooting on the Alexa at 2k.
My problem is i wont be able to do tests till the gear check because the lens are booked up till we shoot. I know the Zeiss 1.3 but not familiar with the super cooke, only the Cooke S4's. All i know is the super cooke are quite old. The ideal would be a side by side comparison to see the differences between the lens. Unfortunately its season here and the gear rental are wanting me to select 1 of the sets.
Anyone have experience with the super cookes? Any comparisons test or frame grabs of work done with the super cookes?
Many thanks,
Jacques
18MM T2.8 SUPER COOKE
25MM T2.2 SUPER COOKE
32MM T2.3 SUPER COOKE
40MM T2.3 SUPER COOKE
50MM T2.3 SUPER COOKE
75MM T2.3 SUPER COOKE
100MM T2.8 SUPER COOKE
#2
Posted 03 November 2015 - 07:14 AM
Since the digital age and the accompanying vogue for vintage lenses there are a number of rehoused sets around, and some recent movies have used them quite effectively, notably Mr Turner.
#3
Posted 03 November 2015 - 09:37 AM
Might explain why i could not find anything on the lens. I copied the details straight from the rate card.
Thanks for your input!!
#4
Posted 03 November 2015 - 04:45 PM
TLS makes the best conversion, they are former Cooke employees and make the Panchros feel like S4s, mechanically at least. Some of the other Panchro conversions have different front element sizes, telescoping fronts when focusing, and the wider lenses can have vignetting and sensor coverage issues. The 18mm Mk1 is especially bad in this regard. On the other hand, the Panchros have a unique vintage look. Don't expect them to look clean like S4s, that's for sure!
#5
Posted 04 November 2015 - 04:05 AM
Hi Dom,
According to the aperture info(around T2.3), it does look like Cooke Speed Panchros SII set. probably a rehoused of some sort. sometimes people give the rehouse a name...send us a photo of them and someone could probably tell you for sure.
#6
Posted 04 November 2015 - 06:04 AM
The series II 18mm (f/1.7 T2) and 25mm (f1.7 T2.2) are not as good and may vignette as Satsuki mentioned.
I'm guessing the T2.8 18mm listed by the OP is a typo and should read T2.2. There can be some confusion with the T2.8 Cooke Panchro series which was released by Cooke only about 10 years ago as a sort of budget S4 range, and subsequently rebranded as Mini S4s. Those lenses have nothing to do with the original Speed Panchros.
#7
Posted 04 November 2015 - 02:44 PM
#8
Posted 16 November 2017 - 09:48 AM
can somebody explain about the Cooke Speed Panchros and his story?
#9
Posted 16 November 2017 - 11:24 AM
https://www.cookeopt.../t/history.html
