Replacing illuminants with LEDs in Practicals
#1 Daniel Meier
Daniel Meier
  • 99 posts
  • Leipzig, Germany
Posted 09 November 2015 - 07:27 AM
Are there any LED illuminants out there that combine high CRI (above 85) and 2700K/2800K color temperature? Ones that nearly can replace incandescent bulbs in terms of skin tone rendering?
I'm looking for E27 and E14 sockets particularly!
Thanks for your input
#2 Phil Rhodes
  • 12283 posts
Posted 09 November 2015 - 07:46 AM
These are promoted on that basis:
http://store.yujiint...-cri-led-lights
I have not tested those devices in particular, but I have tested Yuji's other products and they do indeed have reasonable colour rendering. It's particularly telling that they mention R9-R14 values, which are the saturated colours (including the deep red necessary for good skin tones) which aren't included in traditional CRI calculations.
Also, Kino-Flo make compact fluorescents that are supposedly pretty good - I haven't measured them in particular - but they may not fit some practicals.
#3 Adrian Sierkowski
  • 7476 posts
Posted 09 November 2015 - 01:05 PM
Cree LED, here in the us at least, aren't too bad. There is a green bias, but I am sure they hit somewhere in the 80s in CRI.
#4 Rob McGreevy
Rob McGreevy
  • 45 posts
  • Electrician
  • Austin
Posted 09 November 2015 - 05:23 PM
I've used said Kino CFLs before, I think they're pretty good...they can be dimmed down to around 30% with a variac before noticeable flicker starts, and work great with chinaballs...very bright too. Only thing is like with any kind of kino tube color temp can vary with the age of the fixture - I worked with them on a feature and we had two that didn't match, one had to be corrected at all times. But the good news is since they don't get that hot you can wrap the gel right over them and it won't melt.
These were Kinos 5500 CFLs however, I haven't used the tungsten model but had heard they are pretty equivalent to standard 3200 kino tubes.
#5 Daniel Meier
Daniel Meier
  • 99 posts
  • Leipzig, Germany
Posted 10 November 2015 - 05:47 AM
Thanks a lot to all contributors. Didn't know those Kino CFLs were available. They also sound like a good solution for those cheap softbox CFL-fixtures.
