Hmi Safe Shutter?
#1 Danish Puthan Valiyandi
  • 11 posts
  • Germany
Posted 26 May 2005 - 04:33 AM
I'll be shooting a Musicvideo- using the 16mm Arri SR-3.
Giving easily the possibility to change the Shutterangle- the director wants
me to shoot with an 45° angle.
Anyway- being honest I never shot 45° before :)
Using the rule- Hmi lamps at 50Hz- it wouldn't be a problem shooting
with 45° and 25 fps(?)
Anyway.. I'll be also using Kinoflos... will that be a problem?
Thanks in advance for your answers :rolleyes:
Greetings,
Dan
Edited by Danp, 26 May 2005 - 04:35 AM.
Posted 26 May 2005 - 11:27 AM
The problem with a 45 degree shutter is not FLICKER but EXPOSURE.
Under ordinary AC lights cycling at 50 or 60 hz, with such a short shutter speed, you may catch the pulsing light at the bottom, middle, or the top of the sine wave each time you roll. So you won't get frame-to-frame exposure fluctuations (flicker) but one take may be dimmer than another. With a normal shutter angle, you usually catch two to two and a half pulses per frame. But with a 45 degree angle, you are only catching part of a single pulse each time.
However, with high-frequency AC lamps like Kinos or an HMI on flicker-free mode, it should not be a problem.
#3 Danish Puthan Valiyandi
  • 11 posts
  • Germany
Posted 26 May 2005 - 01:45 PM
Thanks David, I appreciate your answer.
That's everything I wanted to know :)
Greetings,
Dan
#4 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 27 May 2005 - 03:57 AM
I've been shooting in Thailand at 50 cycle hmi in flicker free mode at all speeds and 45 degree shutter no problem. Kinos had no problem either.
#5 Bob Hayes
Bob Hayes
  • 1087 posts
Posted 27 May 2005 - 03:59 AM
David:
Are so saying that regualr Tungsten may have exposure differences take to take with a 45 degree shutter?
Bob
#6 David Mullen ASC
Posted 27 May 2005 - 10:01 AM
David:
Bob
<{POST_SNAPBACK}>
No, just AC discharge type lamps that pulse at 50 or 60 hz.
