Are there 32mm Filter adapters or mounts for Fujian 25mm closed circuit camera lens??
#1 Darren Nemeth
Darren Nemeth
  • 16 posts
  • Waterford, Michigan
Posted 14 November 2015 - 01:23 PM
Hello,
I am going to start shooting 16mm using 70 year old and older 16mm equipment and lenses next summer.
However, I have one new lens that I would like to use.  A Fujian c mount 25mm lens used for closed circuit camera video.
The outer diameter of the front of the lens is 32mm.
Are there any filter mounts, or filter adapters that can be made to fit on this lens??  New or vintage.  It does not matter.
Can anyone recommend filters to look at that will fit?
To give an idea on the project these will be used with a 1920s Cine Kodak Model B, 1930s Cine Kodak Specials, and Filmo 70 series. Nothing modern.
Edited by Darren Nemeth, 14 November 2015 - 01:35 PM.
#2 JD Hartman
JD Hartman
  • 1808 posts
  • Edison, N.J. U.S.A.
Posted 14 November 2015 - 01:46 PM
You live in one of the rust belt states.  If you can't find an off the shelf part, it shouldn't be a problem to find a machine shop that will make the adapter that you need.
#3 Darren Nemeth
Darren Nemeth
  • 16 posts
Posted 14 November 2015 - 01:56 PM
I am looking for something that is readily available.
No camera gear stores around here.  There is one chain store in the next city but it is all new stuff.  Already checked.
Anything that is available from eBay or Amazon will be best.
Getting something custom made will take too long and out of the question. Only paid $25 or so for the lens.
#4 JD Hartman
JD Hartman
  • 1808 posts
Posted 14 November 2015 - 02:24 PM
An adapter can be turned out in much less than a day.  It's not a part for the space shuttle.
When is a bargain, not a bargain.....
#5 Jean-Louis Seguin
Jean-Louis Seguin
  • 777 posts
  • Montreal, Canada
Posted 14 November 2015 - 02:29 PM
Sounds like the filter thread is 30.5mm. A popular size for CCTV lenses. Filters are readily available in this size.
Jean-Louis
#6 Darren Nemeth
Darren Nemeth
  • 16 posts
Posted 15 November 2015 - 07:44 PM
Jean-Louis
Please post an example.
I know little about about modern filters or adapters. Please excuse my not knowing.
