Moisture Static - blue flashes
#1 julietw
julietw
  • 1 posts
Posted 26 May 2005 - 11:53 AM
I'm a post supervisor shooting super 35 mm - 4 perf - in NYC and when the film is tranfered we're seeing blue flashes of light that someone at Technicolor describes as moisture static. Has anyone experienced this or knows the cause?
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 26 May 2005 - 03:25 PM
<{POST_SNAPBACK}>
If the unprocessed film picks up excess moisture (very humid conditions or condensation on a cold roll), the film emulsion gets a bit "sticky" with the added moisture. When two film surfaces are slightly "stuck" together and pulled apart when unwinding the roll, you can generate static that will cause a blue glow at the point of separation.
You can see this effect for yourself. Go into a totally dark room and let your eyes accomodate to the darkness for a few minutes. If you pull the tape off a film can, or perhaps take the protective paper off the sticky side of a "Band Aid" bandage, you will likely see a bit of static discharge as the sticky surfaces separate.
The solution to the problem is to control the moisture content of the film. In really damp conditions, a bit of dessicant (silca gel or molecular sieves) can help keep the opened film roll dry. Always let a can of film warm to ambient temperature before opening, or condensation may form on the film surface if its temperature is below the dew point.
