Elmo 1012 S-XL Camera Issue
#1 Scott Pickering
Scott Pickering
  • 167 posts
Posted 15 November 2015 - 09:37 AM
I have 2 of the 1012 cameras and both have the same issue. When ever the grip is in folded position, allowing the tripod mount to be used, the camera will not power on. Only when the grip is down will it work. Is this common with this camera? What is the fix for it if anyone knows? I have a project I want to use the camera with using tripod, but I may have to skip this camera if I can't get it to function.
#2 Oron Cohen
Oron Cohen
  • 215 posts
  • Tel-Aviv/London
Posted 15 November 2015 - 11:37 AM
This is one of the best super8 cameras ever made to my opinion, I have this camera and never had this issue.
Did you set the main switch knob to "T" when the handle is folded? because if you leave the main switch knob on "ON" mode the camera won't roll....
#3 Mark Dunn
Mark Dunn
  • 2780 posts
Presumably you've referred to the manual:
http://www.apecity.c...acro_manual.pdf
Set the main switch to "T" (for tripod) to run it with the grip folded.
If not, maybe there's a loose wire in the grip, or the interlock switch which the grip actuates in "T" mode isn't working properly.
Edited by Mark Dunn, 15 November 2015 - 11:38 AM.
