2-perf Super8 Anamorphic
305 replies to this topic
#1 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 16 November 2015 - 07:33 AM
I'm wondering what the interest (if any) there would be for a 2-perf anamorphic super8 camera which accepted the normal Super8 cassette but didn't require threading etc.
Price is unknown but it would be higher than 2500$ for sure.
Best regards
Lasse
#2 Joel Rakowski
Joel Rakowski
  • 21 posts
  • United States
Posted 16 November 2015 - 09:14 AM
Sounds cool Lasse,
I'd be interested but probably shy away from using it in a real project unless we could use some 200ft mags with it. I know you guys had mentioned the Logmar S-8 is adaptable to an unreleased larger magazine as well. Would be nice to have something available that works with both.
What kind of glass are you thinking? There isn't a whole lot of anamorphic options for c-mount that I've seen other than adaptors. Also, would using 2 perf of the super 8 frame and then an anamorphic adaptor kind of defeat itself for wide screen? You would be un-squeezing a pretty tall image back into a more standard ratio? Maybe I'm not really understanding what you mean.
Otherwise you guys have my interest if accessories can be interchangeable.
#3 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 16 November 2015 - 09:54 AM
Definitely interested, Lasse!
But can you please clarify the 2-perf design? Do you mean to say shoot the entire 16mm width of Double Super 8 film stock which technically is 2-perf as per the Bolex UltraPan8 3.1 DS8 camera? i.e.
UP8 3.1 (Double Super 8) AR = 1:3.1, FRAME = 13.00mm x 4.22mm; AREA = 54.86 square mm
The Russians had designed something similar with Double Super 8 film but with the classic Cinemascope aspect ratio (AR = 2:55:1). The Zenit link is dead but I could arrange a working link or documents from a Turkish/Russian contact, i.e
"Surprisingly enough the Russians tried it first, i.e.
a.) Quarz 10:
Format frames: 4.22 x5.69 mm (Super), or 4.22 x 10.8 mm (wide)
Focal length: 15 mm
Viewfinder: parallaksny
Drive: Springs
The frequency of shooting: 8, 18, 32 fps
b.) Quarz 2x8S-W (Wide):
Format frames: 4.22 x5.69 mm (Super), or 4.22 x10.8 mm (wide)
Focal length: 15 mm
Office diaphragm: automatic and manual
Drive: spring (5 m)
The frequency of shooting: 9, 18, 24, 36 fps
Dimensions: 197x104x60 mm
Weight: 1.2 kg"
The adapted Russin DS8 cameras were similar to this specimen, i.e. http://tinyurl.com/negp9hh
Or are you referring to halving the height of the Super 8 frame from 4.22mm to 2.11mm? Therefore the proposed aspect ratio (AR) of 2.68:1 with frame dimensions of 2.11mm x 5.69mm.? You would in essence double the run time of a standard 50ft S8 cart from 2'30" to 5'00" at 24fps. But as the image height is decreased the total imaging area available is less than the standard Super 8 frame or proposed full width Double Super 8 Cinemascope design. Hence, a decrease in resolution.
Exciting times!
Edited by Nicholas Kovats, 16 November 2015 - 09:54 AM.
#4 Mark Dunn
Mark Dunn
  • 2783 posts
Posted 16 November 2015 - 10:43 AM
He wants to use the Super-8 cartridge, so I assumed he means Vistavision-style, so 3:1 with a 2x squeeze.
#5 Jay Young
Jay Young
  • 498 posts
  • Lexington KY
Posted 16 November 2015 - 11:03 AM
Interesting notion.
I would be interested in seeing a horizontal pull 8mm cartridge camera, however at 2 perf they'll only last 80 seconds or so...
#6 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 16 November 2015 - 11:08 AM
Exactly Mark
3:1 aspect ratio with standard Super8 cartridge and horizontal pull claw
#7 Will Montgomery
Will Montgomery
  • 2103 posts
  • Dallas, TX
Posted 16 November 2015 - 11:37 AM
That would be more than my 60 second Eyemo loads.  :)
Not as much film real estate as 16mm though. Guess the advantage would be a compact camera and easy loading. But the film costs would be the same as 16mm for the same time...possibly more for processing.
#8 Jay Young
Jay Young
  • 498 posts
  • Lexington KY
Posted 16 November 2015 - 11:41 AM
Yes, and who/what would scan it?
#9 Mark Dunn
Mark Dunn
  • 2783 posts
Posted 16 November 2015 - 11:50 AM
Stretching the VV analogy, I'm hoping for a flat optical extraction to 35mm. silent aperture and 'Scope projection.
Perhaps Quentin would be interested.
Edited by Mark Dunn, 16 November 2015 - 11:52 AM.
#10 Tyler Purcell
Tyler Purcell
  • 4254 posts
Posted 16 November 2015 - 02:07 PM
Yea, I can't see much advantage to 2 perf super 8 with anamorphic lenses. Purchasing appropriate anamorphic lenses can get expensive and shooting costs have doubled, making the whole purpose of shooting Super 8 (low cost) not matter.
By contrast super 16mm would be a similar image size. Since 16mm has lots of other advantages, I don't really see the need for a super 8 camera that mimics something that already exists.
#11 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 16 November 2015 - 02:09 PM
Talk about not thinking "laterally" on my part! I am evidently biased towards the vertical axis. :) Fantastic idea! VistaVision Super 8!
The proposed horizontal 2 perf  frame dimensions = 5.69mm (h) x 8.44mm  (w) w/ AR =  1.48:1 which would be it's flat aperture but with a 2x anamorphic expands laterally to 3:1. The run time is fine. Can't please everyone.
#12 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 16 November 2015 - 02:10 PM
Anyone with a sprocketless scanner. Then rotate the frames ninety degrees in post.
#13 Perry Paolantonio
Perry Paolantonio
  • 551 posts
  • Boston, MA
Posted 16 November 2015 - 02:44 PM
It's not that simple. You're talking about scanning a frame that spans 2 frames. Firmware/software in the scanner would need to be modified so that the count of frames uses ever other perf instead of every perf, and gates would need to be widened to accommodate a wider frame. Some scanners may not be capable of this at all, depending on their design and the coverage area of the sensor/lens.
Theoretically, the ScanStation should be able to do it, and I'm sure the Xena and FlashTransfer machines could probably also be modified, but it's not trivial, and frankly, I think it'd be a tough sell to the makers of these scanners. There's serious engineering time that has to go into that kind of a design change, and you're talking about a one-camera format that may or may not have legs.
It's a neat idea, though I'm not sure it even make sense unless it also involves a 200' mag, since you're halving the duration of the film by doubling the number of perfs per frame.
-perry
#14 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 16 November 2015 - 03:24 PM
Great to hear your real-world scanner input, Perry. Much appreciated. Isn't Carl Lopper in Australia working on a implementation whereby the perfs are NOT utilized as part of the registration and/or frame count? Using the edges? Would be great if the interdependency between frame and perf were optional.
#15 Perry Paolantonio
Perry Paolantonio
  • 551 posts
  • Boston, MA
Posted 16 November 2015 - 04:03 PM
That's essentially impossible - you need some way to know where you are, and perfs are the obvious choice. I'm not sure what Carl is working on exactly, but the frame edges are not a good way to either count frames or register the film, since it's entirely possible for the edges to disappear in to the area outside the frame boundary. That is, on a positive image, a dark frame will have no apparent frame edge because it blends in with the unexposed film around the frame.
Perfs are the only logical choice for knowing where you are in the film.
#16 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 16 November 2015 - 04:57 PM
Hi Perry
We could impose a crosshair between each sprocket for scanner registration.
Granted we havent really thought it through yet it's just an idea we are kicking about at the moment.
Regards
Lasse
#17 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 16 November 2015 - 05:12 PM
Hi Perry
Regards
Lasse
How would you "impose" a crosshair, Lasse? With a tiny backlit aperture or a laser?
#18 Chris Burke
Chris Burke
  • 1748 posts
  • Boston, MA
Posted 16 November 2015 - 05:14 PM
Rather see an "affordable" 2 perf 35mm camera
  • 1
#19 Lasse Roedtnes
Lasse Roedtnes
  • 68 posts
  • Electrician
Posted 16 November 2015 - 05:15 PM
Most likely backlit and not laser to avoid a lawsuit from someone looking into the lens mount and going purposely blind to get a "pay day"
#20 David Cunningham
David Cunningham
  • 1054 posts
Posted 16 November 2015 - 05:30 PM
Ditto on the 2 perf 35 mm
  • 1
