false color and view mode
exposure
7 replies to this topic
#1 YongLee
YongLee
  • 33 posts
  • P.R.C
Posted 07 December 2015 - 09:27 AM
hi ,
   I wonder if the false color effected by the view mode.  the false color will change when view mode from ITU790 to logc or raw ?
   false color in redone  is diffrent to in alexa ?
   thanks!
#2 Devindra Sooknanan
Devindra Sooknanan
  • 25 posts
  • Bay area, california
Posted 09 December 2015 - 09:43 PM
http://www.red.com/l...lor-zebra-tools i think this is for the epics and scarlets but its helpful.  I believe the the false color for the red1mx is tied to the raw recording, not the look you dial in.  I've never used an alexa so i don't really know.
#3 YongLee
YongLee
  • 33 posts
  • P.R.C
Posted 10 December 2015 - 12:09 AM
thank  sooknanan,
but I think the false color was closely related to the view mode , I read the "http://www.red.com/l...r-zebra-tools",it note so.
when view mode from redcolor3 to raw , the false color would change for a same exposure sence.
I hope get more authoritative answer.
#4 Mark Kenfield
Mark Kenfield
  • 1204 posts
Posted 17 December 2015 - 10:24 PM
It depends on the camera unfortunately. With false colour on the Alexa for example, false colour monitoring gives you values related to the image you're seeing through the viewfinder - so if you're looking at Rec709 LUT in the viewfinder, you get false colour values based on that Rec709 curve; conversely, if you're looking at a LogC image, you get values based on that.
It's really frustrating if you're recording in LogC but want to monitor in Rec709, because you have to switch out of Rec709 mode and into to LogC to check your false colour, then switch everything back in order to get your monitoring look again. A whole bunch of convoluted stages that chew up precious minutes over the course of a day.
What you really want (if you're shooting a log format) is false colour tied to the underlying log image, that you can access at the press of a button without having to change or interrupt your monitoring LUTs - that's the way every camera should be setup in my opinion (or at the very least, have the option of configuring it to be that way).
#5 YongLee
YongLee
  • 33 posts
  • P.R.C
Posted 04 September 2016 - 07:56 PM
thank you Mark, very good answer!
#6 YongLee
YongLee
  • 33 posts
  • P.R.C
Posted 04 September 2016 - 08:10 PM
this image is about expose level judged by false color.  my question is whether it is alexa or red false color?   the false color  is not the same as expose to the Caucasian or Mongolia?  who can give me a accurate image indication?
In my experience,when i expose the face, the correct level is the highlight of face appear pink ,is it right? thanks!
#7 David Mullen ASC
  • 20309 posts
Posted 04 September 2016 - 09:07 PM
Clearly in this case, the false color system makes orange & red indicate overexpose and blues to indicate underexposure, so that just leaves pink and green for normal exposure of a face, with the highlights being pink.
#8 YongLee
YongLee
  • 33 posts
  • P.R.C
Posted 05 September 2016 - 09:31 AM
thanks to David :D
