Krasnogorsk 3 Info
#1 Luigi Castellitto
Luigi Castellitto
  • 191 posts
  • Campobasso (Italy)
Posted 16 December 2015 - 10:02 AM
1) The viewfinder is slightly colored yellow, but I read in other post of this forum that is normal, that is ONLY the viewfinder and not the lens, and does not affect on the film.
2) You can put Asa intermediate setting? 125, 160, etc.?
Although the little setting wheel is made for "click" on standard measures, it does not leave a lot of movement between two of "standard" Asa setting. Or is it better put standard measurment (es. 100 Asa for 125 Asa film) and be a calculation of + or - stop and + or - 1/3 of stop with the internal light meter?
3) The footage counter should also work with less than 30 meters on the reel? I mean only a few meters on the reel.
I have a couple of meters of film tests on a reel, but it not move. The internal lever that detects the meter it's ok, it "push" on the reel side.
4) Which way you put the edge of the film in film cutter? Emulsion towards us or towards the machine?
#2 Mark Dunn
Mark Dunn
  • 2783 posts
Posted 16 December 2015 - 11:55 AM
1) Mine has a bit of a tint, removing the lens makes no difference.
3) Yes. The feeler system isn't very sensitive. A foot or two may not move it.
4) It doesn't matter.
Edited by Mark Dunn, 16 December 2015 - 11:56 AM.
#3 Luigi Castellitto
Luigi Castellitto
  • 191 posts
Posted 16 December 2015 - 04:27 PM
Thank you, Mark!
2) You as you adjust for that?
4) I wondered why it seemed to me that the cut of film cutter was slightly oblique. Or not...
As it would be better to cut the film to be inserted: straight, oblique with the tip down or oblique with the tip on top?
#4 Mark Dunn
Mark Dunn
  • 2783 posts
Posted 17 December 2015 - 08:15 AM
I don't know about the meter. Mine doesn't work.
The idea is to cut through a perf to help it engage the sprocket.
Have you seen my Youtube video? I prefer to load by hand.
Edited by Mark Dunn, 17 December 2015 - 08:26 AM.
#5 Luigi Castellitto
Luigi Castellitto
  • 191 posts
Posted 19 December 2015 - 06:36 PM
Ah, I had not seen, it'is a very fast and precise loading.
I, however, still have the loop formers. One day I think to remove them, for now the camera is new and I would not even do this.
I'll have to do it because, in the loading moment, the claw, 90% of the time, does not hook the hole of film, and I do the operation of removal pressure plate and slide the film for engaging the claw in the claw. Perhaps, without the loop formers not happen.
Edited by mbaarviao, 19 December 2015 - 06:37 PM.
#6 Luigi Castellitto
Luigi Castellitto
  • 191 posts
Posted 26 December 2015 - 06:49 PM
For various K-3 users on the forum: I can set 64 Asa (fuji f-64d 16 mm) on the knob on the K-3?
I know I could use an external lightmeter, but the one in my camera works perfectly and I would use it.
I have to set 50 or 100, and do calculations with the stops? I can't understand if the knob of Asa has values of intermediate sensitivity.
