Pushing Film - In the Scan Or in the Grade
12 replies to this topic
#1 Jacob Zalutsky
Jacob Zalutsky
  • 10 posts
Posted 19 December 2015 - 01:16 PM
I recently shot a project where I exposed for a 1 stop push that I had planned to have happen when we scan the film.
I believe we had a miscommunication with the scanning house as it appears they didn't raise the exposure. That said this led me to a broader question - does it matter if you push the exposure in the scan or in the grade? Also, When scanning film to a flat Log workflow where should middle grey sit?
Edited by Jacob Zalutsky, 19 December 2015 - 01:17 PM.
#2 Adrian Sierkowski
  • 7516 posts
Posted 19 December 2015 - 01:26 PM
You would in reality push in the processing. That's what push processing really is.
As for your grade, it depends on what format you scanned into as to how much difference it would make. It would be better to do it in the scan, but 1 stop really isn't all that much.
#3 Tyler Purcell
Tyler Purcell
  • 4469 posts
Posted 19 December 2015 - 01:57 PM
Yep, if you need to push, you'd do that in the photochemical process, not the digitizing process.
#4 Jacob Zalutsky
Jacob Zalutsky
  • 10 posts
Posted 19 December 2015 - 01:58 PM
sure I understand what "pushing" really means - Scan was Pro Res 4444 2K.
I am looking to know if there is any real difference in what is happening technically in the scan that would lead to a better result then in the grade or if there is not much difference. Especially from someone in that industry.
thanks.
Edited by Jacob Zalutsky, 19 December 2015 - 02:05 PM.
#5 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 19 December 2015 - 02:02 PM
I think I am looking to know if there is any real difference in what is happening technically in the scan that would lead to a better result.
...you mean as opposed to the photo-chemical push-process?...
#6 David Mullen ASC
  • 20471 posts
Posted 19 December 2015 - 04:13 PM
I thought there was some sort of standard for a scan in terms of brightness levels.
#7 Robert Houllahan
Robert Houllahan
  • 1674 posts
  • Providence R.I.
Posted 19 December 2015 - 04:29 PM
I have made "standard" scan illumination profiles for various stocks, that said if the negative is very dense or very thin the scanner light levels will need adjustment. The idea of a data scan is to capture the full range of the films density without clipping and without adding any noise. Scanners generally achieve this more (a true RGB slow scanner) or less ( a fast cmos based machine ) and with a full representation of the film density the brightness should be achieved in the grade.
#8 Jacob Zalutsky
Jacob Zalutsky
  • 10 posts
Posted 19 December 2015 - 07:50 PM
Thank you for this info Robert - guessing the result of a scan that didn't properly adjust for a thin negative be increased noise when you do a color grade and lift the picture?
On the digital side I have become familiar with shooting LOG on the Alexa and other cameras and Middle grey might be around 40-45IRE - I'm wondering when you work with a scanner if you would be trying to achieve similar results with adjustments?
#9 David Mullen ASC
  • 20471 posts
Posted 19 December 2015 - 08:23 PM
I've just never heard of asking for a "1-stop push" from a scanner.  Generally a scan goes to uncompressed DPX files and doing a 1-stop boost in color-correction from those isn't really going to increase the noise so much as it would make the grain in the shadows more pronounced.
#10 Robert Houllahan
Robert Houllahan
  • 1674 posts
  • Providence R.I.
Posted 20 December 2015 - 07:34 PM
"Thank you for this info Robert - guessing the result of a scan that didn't properly adjust for a thin negative be increased noise when you do a color grade and lift the picture?"
This really depends, remember that the negative puts the shadows generally in the brightest part of the sensors DR so as long as the scanners sensor is low noise the digital grade wont really produce any more noise than printing up negative in a film to film workflow it will just increase the appearance of the inherent grain in the shadows of the negative. What is more common on the newer faster scanners with cmos sensors is getting sensor noise in the hilites of more dense negative.
#11 David Mullen ASC
  • 20471 posts
Posted 20 December 2015 - 07:44 PM
Yes, that's good to remember, that a thin negative actually causes more light to hit the sensor of the scanner.
#12 Perry Paolantonio
Perry Paolantonio
  • 589 posts
  • Boston, MA
Posted 23 December 2015 - 08:59 AM
The point of a scan is to get as faithful a reproduction of the film in digital form as is possible. So when you do a flat scan, most scanners will allow you to tweak lift, gamma and gain, but we only use those to ensure that nothing is crushed or clipped. That allows the colorist maximum flexibility later on, in tools that are meant to do that kind of work, on monitors that are properly calibrated.
While we could boost an underexposed neg during the scan, I generally wouldn't.'
And yeah - dense neg is where scanners start to have trouble, because you're essentially looking at a low-light situation for the sensor in the scanner, and that means more noise in the picture -- you're pushing the dynamic range of the sensor to its limits in those extremes.
#13 Robert Houllahan
Robert Houllahan
  • 1674 posts
  • Providence R.I.
Posted 23 December 2015 - 02:16 PM
Well that is on CMOS machines, scanners with large pixel CCDs running 1-Tap or some Tri-Linear sensors won't introduce their own noise in this situation, those machines tens to be slow though.
