vertical lines on ground glass?
super 35 film ground glass
16 replies to this topic
#1 Wiliam Cardoza
Wiliam Cardoza
  • 48 posts
  • Salinas, California
Posted 22 December 2015 - 06:14 PM
Wondering what these vertical lines on my ground glass are?
A buddy said they could be rule of 3rd frame lines. Photo wouldn't upload - it's also on my blog http://ihustleandoth...log-post_4.html
BTW this is the the Arri 3C super 35 shifted over PL lens mount that had been listed on this forum.
It has a Jurgens video door.
Super 2:35 or 2:40
Also, I finally got a lens, using an Hasselblad to PL mount - i'm excited to finally shoot something.
I know I could ask the seller but I've never posted on here so I figured I would ask the collective wisdom LOL
#2 Eric H
Eric H
  • 29 posts
Posted 22 December 2015 - 06:33 PM
Ahhh, the old days of optical viewfinders.....The vertical line are light baffles.
#3 Wiliam Cardoza
Wiliam Cardoza
  • 48 posts
Posted 22 December 2015 - 08:38 PM
Thanks Eric.
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 779 posts
  • Montreal, Canada
Posted 23 December 2015 - 10:58 AM
Actually, in your picture, several of the baffles are missing. There should be about six I think.
#5 Eric H
Eric H
  • 29 posts
Posted 23 December 2015 - 02:57 PM
I think there is a typo in the original post.  William must have meant Arri 2c, not 3c. However, I think the number of baffles is correct at 2 or maybe 3.
Edited by Eric H, 23 December 2015 - 02:59 PM.
#6 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 23 December 2015 - 04:06 PM
My Arri 3C has only 2 baffles (vertical) as well, just checked. Possibly something that was changed from the 2C? Mine are centered though, possibly because it's still centered for Academy 35.
#7 Wiliam Cardoza
Wiliam Cardoza
  • 48 posts
Posted 23 December 2015 - 06:26 PM
Satsuki do 3C's actually have variable shutters?
If so could you "please" give me a quick rundown of how to adjust?
Is that what the forward little nob with the arrow is for?
#8 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 24 December 2015 - 01:50 AM
My 3C does. The knurled knob on the dumb side of the body where the handgrip screws in adjusts the shutter. You remove the lens port cover on the front and look at the mirror shutter. Push the knob in and turn until you hear it click into a detent. You should see a black metal plate extend out next to the mirror shutter, effectively making the shutter angle narrower. The shutter angle setting is engraved at the bottom of the plate. Keep pushing and turning the knob to get to all the other settings. Once you hit the last detent, keep turning to reset back to 180.
#9 Wiliam Cardoza
Wiliam Cardoza
  • 48 posts
Posted 14 April 2016 - 11:54 AM
Hi Satsuki, I'd been meaning to thank you.
I finally shot a test and my footage seems normal as per the shutter angle.
A couple times I've tried changing the shutter angle, but as I push in on the knob nothing seems to click; I don't want to push the issue (pun intended) and break something. It just occurred to me, should I turn the mirror shutter out of the way first perhaps?
#10 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 14 April 2016 - 02:44 PM
I think the mirror shutter adjustment knob can get locked up if not used for awhile. Mine was working fine, but I let the camera sit for a year and now it won't move. Probably needs CLA. Maybe Dom Jaeger can chime in?
#11 Dom Jaeger
Dom Jaeger
  • 1928 posts
  • Melbourne, Australia
Posted 14 April 2016 - 07:12 PM
I'm not actually familiar with the 2C/3C variable shutter, only played with one once ages ago. They're not very common in this neck of the woods.
From memory you pushed in a button to hold the variable segment and turned the inching knob to shift around the mirror until the set angle detents locked in. The button could get gummed up I guess, or the variable segment could be bent. I can't remember if the shutter needs to be in a particular position first.
You should be able to take the side cover off to have a look without too much trouble. See my cinetinker blog entry on the 2C for guidance:
http://cinetinker.bl...lex-35-iic.html
#12 Wiliam Cardoza
Wiliam Cardoza
  • 48 posts
Posted 14 April 2016 - 08:05 PM
Thanks Satsuki and Dom.
I just tried again: I pushed the nob and it kind of gave way and traveled and turned a bit further, and I held it there, it was under tension wanting to push and twist back; then I turned the inching nob till it came to a stop. Also, I tried with the mirror turned out of the way first, before I turned the inching knob.
I didn't see the shutter angle plate stick out.
But I think I see what I should look for, is it kind of like a dual prop on a boat?
Is the black plate behind one of the wings of the butterfly (or both) shaped the same as the mirror?
Concept: So as the mirror rotates does it still reflect the light the same as normal into the viewfinder under all shutter angles? But the light is blocked (by degrees) as it turns because of the plate  blocking the light? Something like that right? LOL
Dom i'll check out that link.
Thanks.
#13 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 14 April 2016 - 09:12 PM
Yup, that's the idea. Changing the shutter angle on my camera required quite a bit of force to move knob, for what it's worth.
Btw Dom, would you happen to know if the Master Primes will clear the 2C shutter? I mounted a 32mm the other day and inched the knob. It seemed ok, but I wanted to check before actually running the camera.
#14 Dom Jaeger
Dom Jaeger
  • 1928 posts
Posted 14 April 2016 - 10:05 PM
Master Primes on a 2C eh? That's an interesting combination..
It should be fine. Arri pretty much stuck to the same depth clearance for 35mm over the decades, I've never come across a 35mm format PL lens that didn't clear an Arri 35mm camera mirror/shutter outside of the Angenieux DPs. Always worth checking if you're not sure though. If you can inch the mirror/shutter around with the lens fitted (and set to infinity) then it will be ok to run.
#15 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 14 April 2016 - 10:41 PM
Yeah, I should have taken a picture. It was really sweet to have the 3C with the crystal pistol grip and MP 32mm. Will try to take one tomorrow. Now if only I had 200' mags...
Thanks Dom.
#16 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 16 April 2016 - 03:35 AM
Saw some Arri II 200' mags really cheap on eBay last night.
#17 Philipp Kunzli
Philipp Kunzli
  • 60 posts
  • Zurich & Cologne
Posted 29 April 2016 - 07:16 AM
My Arri 2IIC has 5 buffels. Just as Jean Louis mentioned...
