Canon 514XL: Cool little camera
Canon 514XL
20 replies to this topic
#1 Freya Black
Freya Black
  • 4166 posts
Posted 03 January 2016 - 09:08 AM
I really like this little camera. Does anyone have any experience with it?
It's also a little strange however. I don't seem to be able to make the zoom motor work without the camera motor running. Is this normal?
How does the lens hold up against other canon super 8 cameras?
I was going to get a Eumig mini 5 but this little camera is almost as small!
Freya
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 779 posts
  • Montreal, Canada
Posted 03 January 2016 - 12:08 PM
Yes, it is normal. There is only one motor for both film advance and zooming. Using the power zoom allows the main motor to drive the lens barrel from wide to tele.
#3 Freya Black
Freya Black
  • 4166 posts
Posted 04 January 2016 - 04:09 AM
Thanks Jean!
I thought that might be the case. I guess they have cut a lot of corners in this camera. I'm just hoping there is not so much of that in the actual optics department!
I kind of wish they had added a different feature than the Self Timer. Run lock would have been useful for starters.
I found out something else interesting about this camera.
When you are in single frame mode the camera speed seems to also affect the exposure time of single frames too.
So if you want longer exposures, set it to 9 I guess!
Freya
#4 Mark Dunn
Mark Dunn
  • 2903 posts
Posted 04 January 2016 - 04:33 AM
Thanks Jean!
Freya
IIRC I ran up a cable release out of a 2.5mm jack plug and a bit of twin-core. I don't think I even bothered with a switch, just twisted the ends together. But it would be handy.
The manual says it only meters correctly on single-frame with the switch at 18.
#5 Freya Black
Freya Black
  • 4166 posts
Posted 04 January 2016 - 05:07 AM
My version of the camera doesn't seem to have a 2.5mm socket. Just an old style screw in cable release socket.
Maybe I can screw something into that and use the on/off button to start the camera.
Interesting what the manual has to say. I've been wondering about metering on Super 8 cameras generally because I was toying with the idea of adding more speeds to cameras but wondered how that might affect the metering.
#6 Mark Dunn
Mark Dunn
  • 2903 posts
Posted 04 January 2016 - 06:03 AM
Then you just need a locking cable release. It will bypass the trigger.
http://www.ebay.co.u...7sAAOSw9mFWJL3f
Edited by Mark Dunn, 04 January 2016 - 06:04 AM.
#7 Freya Black
Freya Black
  • 4166 posts
Posted 04 January 2016 - 06:23 AM
Ah! Good idea. Thanks Mark. I don't think the ones I have are locking but I will check and if not I will order one in!
#8 christophernigel
christophernigel
  • 99 posts
Posted 04 January 2016 - 06:28 PM
Freya
Hello Freya , This is a nice camera with a fast lens and has a A/E lock , Also you can fit the canon wide angle c8 .
This and and the canon 310xl are very good camera s and small ,  Filming on the fly/   a good back up camera ,
Theses where not cheap cameras in there day to buy .
Made some good films with them love them .
  • 1
#9 Freya Black
Freya Black
  • 4166 posts
Posted 05 January 2016 - 08:51 AM
I found this Canon Brochure for the camera which was helpful as it lists the filter thread size! :)
http://www.apecity.c...xl_brochure.pdf
#10 Freya Black
Freya Black
  • 4166 posts
Posted 05 January 2016 - 09:19 AM
It seems to be a 40/160 camera.
Does anyone know if there are any issues using this with Tri-X and what settings it needs to be on?
#11 Freya Black
Freya Black
  • 4166 posts
Posted 05 January 2016 - 11:40 AM
Thanks Christopher,
  I like the super fast lens on the 310xl but there is no 9fps unless you get the Pro8 modded camera.
  I have thought about getting an original canon one cheap and seeing if I could get it to do 9 tho.
Freya
Edited by Freya Black, 05 January 2016 - 11:49 AM.
#12 Mark Dunn
Mark Dunn
  • 2903 posts
Posted 05 January 2016 - 12:10 PM
If you google 'super 8 cartridge notch' there's a download to tell you how it will meter Tri-X if the cartridge is speed notched. It will be either 160 or 250. More likely 160. Both are doable but you can mod the cartridge if you have a preference.
There are some threads on here about it.
Edited by Mark Dunn, 05 January 2016 - 12:15 PM.
#13 Nick Collingwood
Nick Collingwood
  • 152 posts
  • New York, NY
Posted 05 January 2016 - 05:35 PM
I've got it! My first Super 8 camera in fact. I like it. Super light so it's great for traveling with. Not the sharpest lens around and I'm an amateur but I've liked my results so far. I also have the C-8 Wide adapter which helps with the 9mm focal length.
I just joined this forum so I'm not sure if it's ok to link youtube but here's a trip I made this July to the Dominican Republic (50D). First Super 8 roll I ever shot actually! And this is me walking around NYC with some friends and exploring Ellis Island (200T).
And it only takes 2 AAs which is the lowest of any Super 8 camera I believe. I got it for only $35 so it was worth it. I've used it on a few trips since then. The 9fps is good for timelapses when telecined at 18fps.
Hope this helps you get a feel for how it looks and my experience with it.
  • 1
#14 Freya Black
Freya Black
  • 4166 posts
Posted 07 January 2016 - 07:28 AM
Hiya Nick!
...and welcome to cine.com!
Your posting kind of got stomped on by the new announcement.
I was also impressed by only 2 AA batteries.
Seems like it would be very economical.
I'm trying to run it a little everyday to get it back into the swing of things.
I think 9fps will be useful for a lot of things. Low light for instance.
I'm wondering if the lens is softer than the other canons. A lot of them seem to have similar lenses.
Thanks for posting! I have a good feeling about this little camera. :)
Oh and it's definitely okay to link to video's. People do it all the time!
Edited by Freya Black, 07 January 2016 - 07:29 AM.
#15 christophernigel
christophernigel
  • 99 posts
Posted 07 January 2016 - 11:56 AM
Hiya Nick!
Freya it good to have a good feeling over this camera she really is a nice gem also get the 310 XL if you can and the C8 which can be hard to find . But worth it .  Was so happy when I got my one along with the 310xl and c8 .
was really a great design , That came out in the 70's /a camera down to f1.4 and the canon 310xl down to f1  thats a Wow .
#16 JB Guillot
JB Guillot
  • 79 posts
  • France
Posted 11 January 2016 - 06:18 AM
Got a couple 514 XL home as I bought them for really cheap (like 20-25€).
A fair compact camera to bring along whenever you're out.
I like the compact size and the additional C8 attachement for "wide" angle shoots.
Even if lens is a bit soft, it works fine with fast film (ISO160) so that aperture is rather closed.
I also use the 10sec run feature from time to time if I want to appear of the film. For longer shots I use a release cable with lock ring.
On the other side, the lens focus ring is really loose which is not so great for accurate focusing. But with a bit of practise you can have decent images. Some will also notice the lack of high speeds (25 fps or higher) but for regular 18 fps clips it does the job.
This clip was shot entirely with 514 XL (but with a Panasonic adapter that turned wide angle shot to absolute crap as focusing wasn't accurate). Scan quality is bad but anyway ...
#17 Freya Black
Freya Black
  • 4166 posts
Posted 11 January 2016 - 12:25 PM
I've been trying to get the camera to work with a Century Anamorphic adaptor but I'mm not having much success. I seem to get fairly mild vignetting when it is most telephoto and most wide with more severe vignetting in between rather oddly.
The 514 XL-S works a lot better with really mild vignetting but of course it has no 9fps. :(
Freya
#18 Mark Dunn
Mark Dunn
  • 2903 posts
Posted 11 January 2016 - 12:36 PM
Freya
That sounds odd. Care to post a photograph of your setup?
#19 Freya Black
Freya Black
  • 4166 posts
Posted 12 January 2016 - 06:56 AM
A big hastle to post photos but my setup is just a 43mm to 37mm adaptor ring. Nothing special it's to do with the way the glass moves internally in the canon zooms.
#20 Mark Dunn
Mark Dunn
  • 2903 posts
Posted 12 January 2016 - 07:04 AM
If you are stepping down then vignetting is probably inevitable. The rear element may simply be too small.
You could put pix on photobucket or the like.
Edited by Mark Dunn, 12 January 2016 - 07:05 AM.
