Car Mounting [absolute new comer]
12 replies to this topic
#1 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 03 January 2016 - 12:33 PM
Hello,
So I have a project coming up which involves mounting a camera on a car at various angles. I have attached images for reference.
I have a poop load of queries so here goes -
1 - The camera I am thinking of is a 1 D C ? Would it be too heavy for suction rigs or is it ok ? Will it cause vibrations ? Would the a7s ii be a better choice ?
2 - How long does it take to set up a car rig ?
3 - Is there some sort of a rig to stabilise a tripod in the back of a car ?
4 - What are the kind of rigs that I need to look into ? Whats a good place to start reading about this ? What do they roughly cost per day ? In short as a DOP what do I need to know before I start off on my project
5 - My car does not have a bonnet in the front but the director wants a two shot from the front ? Is it possible to rig up such a shot ?
6 - I also need to take a shot of the speeding road signs [attached image] from low from the front of the car ? Is such a shot possible ? What kind of a rig does it require ?
#2 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 03 January 2016 - 12:37 PM
My car
#3 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 03 January 2016 - 12:39 PM
Road Divider Sign
#4 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 03 January 2016 - 12:46 PM
Angles I require
#5 JD Hartman
JD Hartman
  • 1808 posts
  • Edison, N.J. U.S.A.
Posted 06 January 2016 - 11:45 AM
Should be doable with a three point mount.  How heavy is the camera?  More ridged would be two anchor points on the bumper, the third, the roof or the windscreen. Don't forget to safety the camera/cheese plate to a fourth anchor point independent of the others.
#6 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 09 January 2016 - 09:59 PM
Hire someone who knows how to rig cameras. Its cheaper than buying a new camera.
#7 JD Hartman
JD Hartman
  • 1808 posts
Posted 10 January 2016 - 07:27 AM
Got to learn sometime, might as well be with your camera.
#8 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
Posted 23 January 2016 - 11:01 PM
You are looking to attempt a hood mount type of shot on a car that has no hood.
Trust me when I say this is better attempted by someone with experience.
Losing your camera is one problem.
A far bigger one is hurting or killing someone with a camera / rig flying off a car.
I am guessing you plan to drive this car on public roads with no lock down ?
#9 JD Hartman
JD Hartman
  • 1808 posts
Posted 24 January 2016 - 08:44 AM
My impression is that this shot is going to happen, professional help or not.
One alternative to a proper car rig or process trailer would be shooting it from a camera mounted in the bed of a pickup truck, pulling the car behind it with a simple tow bar.  But as Sanjay Sami says, any car shot should be done on closed roads.
#10 JD Hartman
JD Hartman
  • 1808 posts
Posted 24 January 2016 - 11:04 AM
Towing the vehicle and shooting from the bed of the tow vehicle, depending on road conditions, could be very shaky.  Just a thought.
#11 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 27 January 2016 - 03:21 PM
Vivek,
Here is a car mount tutorial I produced for Video Gear.
Stuart Allman
illuma.blogspot.com
#12 Jon Kline
Jon Kline
  • 45 posts
  • Chicago, IL
Posted 27 January 2016 - 07:21 PM
If you're shooting a lot around this vehicle, you definitely want a process trailer. It will make producing, acting, and sound easier, too.
If you're totally run and gun, a stabilizer like a MoVI, combined with a good driver, can give you some options. Take a little air out of the tires to help smooth things out, too. But it's pretty much impossible to get the same take twice once you're working with two vehicles that aren't attached.
#13 JD Hartman
JD Hartman
  • 1808 posts
Posted 27 January 2016 - 09:02 PM
Nice video.  Disagree on the procedure for cleaning the vacuum cup face.
Excerpted from the Wood's Powr-Grip site:
 To CLEAN THE VACUUM PAD, remove the air filter from the pad face. Use a clean sponge or lint-free cloth to apply soapy water or another mild cleanser to the cup face.
Never use solvents or rubber conditioners as a cleaning agent
Do not use harsh chemicals (such as solvents or gasoline) or unauthorized rubber
cleaners and conditioners to clean the cup. See www.WPG.com for more information
Edited by JD Hartman, 27 January 2016 - 09:03 PM.
