Arri SXU-1 Lens data
remotefocus follow focus arri sxu-1 smc-1
#1 Simon Bengtsson
Simon Bengtsson
  • 16 posts
  • Sverige
Posted 04 January 2016 - 11:05 AM
Hi everyone!
I will get my hands on the Arri SXU-1 System for the first time and i was wondering a bit about lens data.
Is it possible to get lens data to the hand unit with a SMC-1 motor controller or do i have to step up to the WCU-4 system?
We are on a budget and i can't afford the WCU-4 and it is not entirely necessary to have the lens data, it would be nice though :P
And if anyone used it before, how does it handle? Are the CLM-4 Motor strong? I will be using Zeiss HS mkIII and a LMB-15 mattebox (clip-on).
I've hade some issues with heden motors that aren't strong enough to pull the lens barrel, especially in cold weather.
#2 Tuomas Viitakoski
Tuomas Viitakoski
  • 8 posts
  • Helsinki
Posted 08 January 2016 - 05:39 AM
Tjäna Simon,
SXU-1 is not compatible with the LDS, so you need to have a WCU-4 and a receiver (Alexa Plus, UMC-4) as well.
CLM-4 motors are not the strongest ones but have a decent torque (can be adjusted from settings).
Depending on how old and worn they are - some of the HS lenses, like 18mm for example, may get stiff when there's a clip-on attached. So if you experience any trouble you may have to change it to rod mounted MB.
Good luck!
-Tuomas
Also tagged with one or more of these keywords: remotefocus, follow focus, arri, sxu-1, smc-1
