Bolex Servicing/Repair in Toronto?
Bolex Toronto 16mm Canada Repair
#1 Noah Henderson
Noah Henderson
  • 4 posts
  • Belleville
Posted 04 January 2016 - 10:04 PM
Does anyone out there know of someone in Toronto that has the ability to service a Bolex H16?
I recently received an old Bolex to my great delight as a gift that I want to shoot on and I have the resources (stock, access to processing, ect.) to do it, but it seems that the camera needs a bit of care in order to get it running again. It winds, the motor runs, and film moves through it properly, the issue though is that it does not keep a constant speed and will slow down at the end of the wind or if it’s in the middle of a roll of film, move very slowly as though the motor is weak. I don’t know nearly enough about the inner workings of this piece of gear in order to consider opening it up and I think that most likely it needs to be cleaned and lubricated.
I’m hoping to find someone in the city to do it because I don’t have the money to ship it off somewhere else and get it serviced. It’s also a non-reflex model so it is quite old and I don’t know the history behind it so I can only assume it’s been a very long time since it’s received proper care.
#2 Tyler Purcell
Tyler Purcell
  • 4463 posts
Posted 05 January 2016 - 02:40 AM
Welcome to the forum Noah!
What you're describing is pretty typical for a wind up camera. The wind itself only lasts a few seconds and as the spring unwinds it has less and less torque to move the take up reel, so it will slow down. Generally speaking, a full 100ft roll of film will need several winds to complete. The moment you hear the camera start slowing down, that's when you stop shooting and wind it up again. The later cameras have a better regulation system, but no matter how much regulation you have, it's still a spring based system and the spring dictates everything.
Unfortunately, servicing Bolex cameras requires many specialized tools, it's not something a regular camera tech can do. There are two speciality Bolex service shops in the US, though I don't know of any in Canada. They're expensive, but worth the price.
I personally love the wind up Bolex cameras. When you learn how to use it well, you can do all sorts of neat tricks. One of my favorite is to set it at the highest speed it will go and with an unwound spring, start cranking the spring and you will control the speed of the camera via your hand motion. It gives you a very old-time cinema look with each frame being exposed differently. Of course, it has a great stop motion function as well, rewind function (for double exposure and dissolves) and no batteries required! I can't tell you how much of a pain butt it's been getting my electronic bolex working due to the aging electronics. :(
Hope that helps!
#3 Andries Molenaar
Andries Molenaar
  • 712 posts
  • Amsterdam
Posted 05 January 2016 - 03:38 AM
Try forummember:
Jean-Lois Seguin in Montreal
bolextech@gmail.com
He is active in the super-8 section. Check his posts.
Edited by Andries Molenaar, 05 January 2016 - 03:41 AM.
#4 Nicholas Kovats
Nicholas Kovats
  • 526 posts
Posted 05 January 2016 - 09:08 AM
A second warm welcome to the forum, Noah. And welcome to the wonderful precious world of photo-chemical film!
I also reside in Toronto and there is only one recommendation and it is simply the best. Jean-Louis Seguin in Montreal services, re-manufactures and offers the best Bolex Clean-Lubricate-Adjustment (CLA) bar none. He services all my Bolex's and many, many others. Not expensive and worth every penny. He is a treasured global resource and will respond to your queries promptly.
Please feel free to utilize me as a reference. Check out my Facebook page for lots of photos of his serviced and re-manufactured Bolex.
All the best,
Nicholas Kovats
https://www.facebook...8WidescreenFilm
Edited by Nicholas Kovats, 05 January 2016 - 09:08 AM.
#5 Mark Dunn
Mark Dunn
  • 2896 posts
Posted 05 January 2016 - 09:11 AM
If the regulator is working properly, it doesn't slow down. It runs at constant speed throughout the wind. Even my K3 does that.
#6 Tyler Purcell
Tyler Purcell
  • 4463 posts
Posted 05 January 2016 - 12:23 PM
Yes, it will run at a constant speed until the end of the wind, where it will taper off. Some of the earlier Bolex cameras don't have a decent regulation system. I remember using one once and being shocked how much it tapered off compared to the later models. Since the OP mentioned his camera NOT being a reflex model, it's one of the very early cameras then. So I was just saying, his problems maybe normal. It's hard to tell without a physical examination.
#7 Noah Henderson
Noah Henderson
  • 4 posts
  • Belleville
Posted 05 January 2016 - 01:03 PM
I believe that it should taper off, but not as much as it does. If it's in the middle of a roll it will run for only a couple of seconds before barely being able to move the take up reel and that's on a full wind. At the state it's in it would be useless to actually try and film anything with it.
I've contacted Jean-Lois Seguin and it sounds like he is my best choice and his price is really good.
#8 Nicholas Kovats
Nicholas Kovats
  • 526 posts
Posted 05 January 2016 - 01:05 PM
Excellent investment in rejuvenating your 60+ year old camera!
#9 Richard Jura
Richard Jura
  • 22 posts
Posted 11 January 2016 - 09:44 AM
Welcome
 A reflex camera will take 21 1/2 turns to wind fully, which in turn gets you approx 28 seconds @ 24FPS. I've been rebuilding them since 1981, somewhere in the mid 90's they switched to a different supplier for the spring material (China???) and after that I was lucky to get them to run
24FPS for a good 20 seconds, regardless of what I did to them mechanically or the type of lube I used.
Here's a batch of motors which could not be sent back to Bolex for new springs as the outer gear ring was damaged.
They got so bad guy on the west coast was modifying the wind mechanism so they would only crank about 17 turns.
A look into the workings of a Bolex.
https://youtu.be/v0IqUUnNcdg
Rich
Couldn't get it to embed
Edited by Richard Jura, 11 January 2016 - 09:48 AM.
