Cp-16a tilted viewfinder
#1 Patrick Lewis
Patrick Lewis
  • 19 posts
  • California
Posted 09 January 2016 - 02:49 AM
Hello everyone. I've recently obtained a CP-16A (non-reflex), with a tilted frame in the finder. How would one go about leveling it to match the orientation of the camera? Is there a mechanism in the dog leg finder itself, or do I rotate where the lens mounts? I can't seem to find any information on this. Thanks for your help.
Edited by Patrick Lewis, 09 January 2016 - 02:51 AM.
#2 Brian Drysdale
  • 5343 posts
Posted 09 January 2016 - 08:47 AM
You should find a ring on the viewfinder with small grub screws that can be unscrewed with a jewelers screwdriver,
Hang a piece of string with a bob weight from the wall to get your vertical. Ensuring that the lens is in the position you wish to use in, mount the camera on a tripod, ensuring that it's level by the bubble; then loosen the grub screws and adjust the ring so that the frame lines line up with the vertical string. Finally tighten the screws.
#3 Brian Drysdale
  • 5343 posts
Posted 09 January 2016 - 09:15 AM
Re the above,  loosen the grub screws, don't remove them
#4 Patrick Lewis
Patrick Lewis
  • 19 posts
  • California
Posted 09 January 2016 - 10:33 AM
Thanks! I'll give it a shot.
