Lens diameter with Matte Box
#1 Jared Bedrejo
Jared Bedrejo
  • 23 posts
Posted 11 January 2016 - 04:44 AM
Not sure if this is covered anywhere, but has anyone had any experience with using a 4x4" matte box with any prime lens' like the CP.2/CN-E? I have a set of Rokinon primes and I know that the 4x4" should be fine with them but I'm unsure if the lens diameters of the CP.2/CN-E primes would fit a 4x4". Or should I just go for a 4x5.65"? The cheaper the better!
Edited by Jared Bedrejo, 11 January 2016 - 04:45 AM.
#2 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 11 January 2016 - 02:43 PM
if you do the inch to millimeter conversion  4x4 filters are just over 100mm wide and the diameter of Cp2's is 114mm so you might have some issues. That said I don't think it would be much of a problem unless you are really wide focal lengths... just make sure the matte box has an opening wider then 114mm and you can get a the right clamp ring/donut to use those lenses.
If you are building a kit and want industry standard gear though 4x5.6 is the standard and I would go in that direction.
#3 Jared Bedrejo
Jared Bedrejo
  • 23 posts
Posted 11 January 2016 - 07:20 PM
Got it. Thanks Albion.
#4 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 12 January 2016 - 07:08 AM
Also, the glass element is way smaller than the outer diameter of most lenses, so I think you are good for most focal lengths, but yeah 4x5.6 is safer if you are buying.
#5 Albion Hockney
Albion Hockney
  • 493 posts
  • LA
Posted 12 January 2016 - 11:14 AM
Yes, for the most part this is true - if you are using higher end lenses like Master Primes/cooke s4's you might have some issues but even then the element is inset a little bit.
