Photo Sonics 1VN power
photo sonics 1vn actionmaster 200 battery power
#1 aapo lettinen
aapo lettinen
  • 1159 posts
  • Finland
Posted 14 January 2016 - 08:39 AM
I just got a Photo Sonics 1VN (action master 200) in unknown condition and no batteries.
What kind of battery (voltage/amps) the original uses inside the "shoulder mount" adapter which is supposedly meant for sports high speed filming? the battery case itself is there but the cells are removed. I am planning to fit NiMh cells there once I know the voltage and power needed.
and, is there some of the original lubricants available anymore or some alternatives for the movement? I won't use it regularly even if I get it working but may have to use it in cold temperatures (about -20°C or so) . maybe a 200ft roll once a month or so...
#2 Nicholas Kovats
Nicholas Kovats
  • 522 posts
Posted 14 January 2016 - 09:51 AM
Contact Brent Finely in the US. He is Mr. Photo-Sonics and he can help you, i.e. http://www.brentfinley.com/cinesvc.htm
Edited by Nicholas Kovats, 14 January 2016 - 09:51 AM.
  • 1
#3 aapo lettinen
aapo lettinen
  • 1159 posts
  • Finland
Posted 14 January 2016 - 09:54 AM
great, thanks a lot  :lol:
I found some info that it's supposed to be 28vdc +/- 4v.  Maybe 20 or 21 NiMh cells would work.
I will also ask him if acetate base 2R film would work with the camera, 2R polyester base is very difficult to find
#4 Mark Dunn
Mark Dunn
  • 2780 posts
Posted 14 January 2016 - 10:09 AM
The determining factor will be the current drain, likely to be upwards of 10A, so make sure the cells are up to it.
There's no problem using acetate base for medium-speed cine.
You must be aware by now that it doesn't have a viewfinder.
Edited by Mark Dunn, 14 January 2016 - 10:10 AM.
Also tagged with one or more of these keywords: photo, sonics, 1vn, actionmaster, 200, battery, power
