Processing LOG for broadcast
#1 Tyler Clark
Tyler Clark
  • 78 posts
  • Ohio
Posted 14 January 2016 - 01:45 PM
Using the C300 I find the look is there using adjustments without throwing on a LUT.
Would using this method have negative effects when going to broadcast as opposed to web?
#2 Stuart Brereton
Stuart Brereton
  • 3485 posts
Posted 14 January 2016 - 02:41 PM
LUTs are just a shortcut to get you to a usable look very quickly. There are many other ways to get there which are equally valid, as long as the final image remains broadcast legal.
#3 Robin R Probyn
Robin R Probyn
  • 2613 posts
  • Tokyo
Posted 14 January 2016 - 09:13 PM
C300 log is more of a Log lite gamma.. its very much the same as Sony hyper gamma 7/8.. Canon have done this because of the C300 being only 8 bit max.. and cant really handle a true log gamma.. and so its no where near as desaturated/lacking contrast as Sony Slog of Arri LogC .. and so easier to deal with in post..
#4 David Mullen ASC
  • 20468 posts
Posted 14 January 2016 - 09:35 PM
Yes, Canon-Log is even milder than PanaLog was in the Genesis, it's almost just a low-contrast Rec.709 like HyperGamma.  I don't think you absolutely need a LUT to convert it to Rec.709, you just have to adjust the contrast and black levels to taste.
#5 Robin R Probyn
Robin R Probyn
  • 2613 posts
  • Tokyo
Posted 14 January 2016 - 10:08 PM
Re for broadcast.. as Stuart says .. you just need to have your levels.. e.g. white 100% etc legal for broadcast .. nothing to do with the aesthetics in itself..
